Question about HP Pavilion F1703 17" LCD Monitor
My hp f1703 Monitor goes off or black after being on for a few hrs, it flickers at top the cuts off, if I switch it back on within a min or so it repeats, if I leave it for a while it comes on for three to six hrs. Any thoughts. Paul
  • 49 Answers
It may be the back light on the monitor going out.
If you turn off the lights in the room, close the blinds & curtains can you see any image on the screen?
If so then it is the backlight. it is sort of a fluorescent light in the monitor that will go out over time or if gets jolted too many times.
Check repair cost first it may be best to replace it. I saw 22" monitors on tigerdirect.com for less than $150.
Turn off monitors when not in use. there is a limited time on anything just like a light bulb gives up after so many hours.
Posted on Jul 31, 2009
HP Pavilion f1703 Monitor flickers on & off
Clean and resolder all four round inductors, check the caps, replace them if they have bulging tops (even slightly bulg). Check the transistors (c5707) for shorts. See pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 25, 2010 | HP Pavilion F1703 17" LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
Screen goes black and when tuned off for a while will come back on and sometimes flickers like it has a bad connection. It is a hp pavilion f 1703
bmiller013, Problem been around for some time!!! Surf over to this blog and do some reading first. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then you can come back to this posting and rate it if it helped you find out why your monitor has crapped out on you. Good luck with the repair guy. 12fixlouie
Mar 11, 2010 | HP Pavilion F1703 17" LCD Monitor
My VGA signal is active but I have no DVI signal.
You must just have one port to be active.
Let's say you want to use the VGA then it should only be the one plugged-in and vice versa
you can't have both ports to be connected at the same time.
Feb 28, 2010 | HP Computers & Internet
Monitor screen is black when hooked up to my laptop.
u have to set screen resolution of monitor to 1024 *768
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
240 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
