Question about Whirlpool Duet GHW9150P Front Load Washer
My washer wont start.
I'm trying to do a load of laundry and my washer wont start, it just beeps and then the letter F pops up then the letters dl after. what do i do?
  • 15,935 Answers
FDL error = Function Door Lock Error
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa -a Very Helpful Rating is appreciated for answering your FREE question.
Posted on Jul 31, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. This error code occurs due to the following reasons--
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
Kenmore Elite Washer
Door lock error replace the door lock switch
May 16, 2010 | Kenmore Elite 45986 Front Load Washer
My washer has an F dl problem?
Fdl is a code that indicates a door lock error. The clicking sound that you hear is most likely the door lock. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F h display with beeping
I have a similar problem. It stops and beeps. It seems that the connections to the control unit are really cheap. Every time this happens which is evry time the machine is used, I take the top lid off and jiggle the black plugs into the control unit and it starts. The repair guy told me to replace the control unit, whcich I will have to do before my wife stops doing laundry. This is a 3 yeard old machine.
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Letters UE on display
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Washer won't start. falshing the letter F then the lower case letters dl.
DL means you have a draining problem.
Clean filter, drain and or pump
Jul 28, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
217 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
