Question about DeLonghi Pinguino PAC-290 Air Conditioner
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
  • 724 Answers
Sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Posted on Jul 31, 2009
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
The window unit is turned on, but doesnt seem to be very strong with blowing cold air . is there something that can be checked on the unit? something that can be replaced on the unit-like a filter? since...
first make sure the filter and coils are clean, then be sure you have it set for recirculate and not outside air allowance, and if ou wait til the room is very hot it will take a while to cool that room down to a comfort level. the fan and temperature control should both be at maximum if the room is very hot.
Jun 25, 2009 | Heating & Cooling
Blows warm air
you need to disassemble the rear fan shroud and clean the back of the condensor. If the compressor runs and the lines are cold, it is dirty. The rear condensor is the one discharging the hot air. Both sides must be clean and free of dirt/grime
May 06, 2009 | Sunbeam Heating & Cooling
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
DeLonghi Pinguino PAC-290 Air Conditioner Logo
260 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
