Question about SanDisk Sansa e250 MP3 Player
Describe your sansa mp3 playI downloaded a ton of new music onto my Mp3 player and when i unplugged it from my coputer the screen said refresh database and a green square appeared. When the refreshing square is completely filled, my mp3 screen turns blank.er troubleshooting Problem
  • 820 Answers
Support for SanDisk e200 series:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200v2_userguide_en.pdf
answer for freezing while updating database:
http://kb.sandisk.com/app/answers/detail/a_id/189
updating to new firmware [this will erase all data !]
http://kb.sandisk.com/app/answers/detail/a_id/306
Posted on Aug 01, 2009
mixmaster
  • 626 Answers
SOURCE: refresh database message
Run the recovery tool from the SanDisk website. Make sure you select format when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 10, 2007
SOURCE: refresh database on screen
how do you put on recovery mode?
Posted on Dec 02, 2007
SOURCE: stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Posted on Jan 20, 2008
SOURCE: sansa mp3 player freezes at refresh database
hi guys,im an foreign exchange student from Turkey.I had the same problem on my device .I just fixed it 2 minutes ago.Ive tried to figure out about a hour.But solving was pretty easy.There is my solution;
1)go to computer and click on right click on your device icon
2)go to PROPERTIES
3)go to TOOLS
4)There says EROR-CHECKING
5)click on CHECK NOW
6)and in 30 seconds it says there is a trouble found and fixed
7)and thats it .
Posted on May 05, 2008
SOURCE: Sansa e250 has Refresh Database Frozen
Look at this site:
http://www.expansys-usa.com/ft.aspx?k=89682
follow the steps showed by MrSinister27
It worked for me!!
Posted on Jul 23, 2008
How do i download music onto my Sansa Clip MP3 Player
you can try to use a youtube downloader to download videos to your Mp3, here is the one i use for long which can not only download videos from youtube but also convert videos to Mp3 while it is downloading. hope this helps for you.
Jul 09, 2012 | SanDisk Sansa Clip MP3 Player
Cant see music when i unplug my sansa
See my tip posted here -->
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
<---- copy and paste this address into a new window or tab.
Mar 14, 2010 | SanDisk Sansa Clip MP3 Player
I cannot acses my ipod from computer to update my songs
First, plug both ends if the wire in the right places. Then, after you log in, turn on your mp3 player. My Sansa Fuze will appear in the My Computer folder; yours probably will too. To add anything, you have to access it from My Computer-> [name of mp3 player] ->Music/Video/Pictures to add these things. While you're pasting stuff to the mp3 player, the screen of the mp3 player will say "writing"- don't unplug your mp3 player until the screen just says "connected". The media will refresh, and the content should be available
Feb 04, 2010 | SanDisk Sansa e250 MP3 Player
How can I completly clear the files in my sansa e250? I "deleted" everything off the mp3 player using my computer. so when I open the sansa file (from my computer) to view the contents in the device, it...
First you need to redownload the firmware. That is something that you can download straight from the manufacture. Then you want to unplug your mp3 player and go to settings. In the bottom of your settings it should have a option to restore to factory settings.
Sep 24, 2009 | SanDisk Sansa e250 MP3 Player
It froze up and now the screen is all blue
take the battery out leave out for 10 min then put back in should clear up the freeze
May 24, 2009 | SanDisk Sansa e250 MP3 Player
Screen went blur after downloading music
Try refreshing it if that dioes not work go to sansas website and call their tech support for your area.
Apr 17, 2009 | SanDisk Sansa e270 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Help
check if the format of the music is in mp3 format this happened to me and i was told to change the format, see if this works.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Frozen on Refresh Database
Take out the four screws on the back and pop out the battery then put it back on. Make sure you synced the songs properly. Add to the problem how you added your songs and I might be able to help.
Good Luck
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
85 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
