Question about Kenmore 400 6942 Dryer
Kenmore D433ele will not turn off...will not heat
Kenmore dryer D433ele will not turn off...will not heat up
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 05, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
No heat
Good day,
Kenmore dryers are built by Whirlpool. Here is an excellent tutorial on replacing the element.
http://www.applianceaid.com/wp_element.html
Feb 03, 2010 | Kenmore Dryers
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
Kenmore gas dryer that turns but does not heat up
mostly you need a thermal fuse,,take the back of ,,maybe 12 1/4 nut driver screws,,you will see a little white fuse,,replace it..onthejob
Jan 12, 2009 | Kenmore 74902 Gas Dryer
No heat at all? does the top of the machine heat up, but not the drum? could be your drum seal is damaged or slipped off.
If the firebox doesn't light up, could be your igniter, the unit's safety switch, thermocouple, or regulator; Your Gas Company may provide a service that would check it for you... some do.
Jan 02, 2009 | Kenmore 74602 Gas Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 400 6942 Dryer Logo
214 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
