Question about Acer Computers & Internet
The CineDash Media Console doesn't react
I have a simular problem, my lights do work, but I can't change the volume, while my hold button is not on. Does somebody know how I can fix it?
  • 335 Answers
Yes!
Acer has a few known issues with the CineDash technology. Please call their technical support and they will do some troubleshooting with you to determine if it a hardware issue or not. If it is, they will likely repair it free of charge as there are known issues with it.
use the force!
Posted on Aug 09, 2009
I have an acer8930g with cinedash media console. however when using the next track button with spotify it often skips 2 or 3 tracks instead of just skipping the current track.
It sounds as if you should re-install the program. Or you may just have a sticky keyboard. or the key repeat time is very fast. Try looking in the control panel for your operating system and adjust it from there.
Apr 12, 2013 | Acer Computers & Internet
Cinedash starts with the volume off, even though the volume is about 50% on the computer. when I try to increase the volume using the Cinedash it freezes launch manager. When I reload launch manager the...
Hi there. I see you are having a problem with a media software program on your pc. The best thing you can do to solve the problem is to uninstall and then reinstall the program. This will put it back into its default settings and will also correct any corruption that the current installation may have. I hope this helps you.
Mar 11, 2012 | Apevia Computers & Internet
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
Unlock volume console
Hi, Try doing the following:
1. Turn of your laptop 2. Remove the battery and the power cable for about 15 seconds 3. Reinsert the battery and the power cable 4. Turn on your laptop.
Your Cinedash Console should be fully functional again
Good luck. Cheryl
May 28, 2009 | Acer Aspire 6920 Notebook PC
Cinedash touchpad
Try taking the battery out for 10 seconds, put it back in and boot as normal.
Worked for me on my Aspire 6920G! I think it must be a power-ratio problem.
Mar 29, 2009 | Acer Aspire One PC Notebook
Volume touchpad has frozen on mute
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
Jan 17, 2009 | Computers & Internet
My CineDash Media Console will not work anymore. The volume, stop, play, etc. does not work. Not with itunes anymore.
This is the way to get it to work!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager here (hosted here) or go to the acer site and find it there. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Nov 06, 2008 | Computers & Internet
I have an acer aspire 6920 laptop.the cinedash media console isnt responding
Functions are activated by simply tapping
the function with your finger, while you can adjust volume by sliding your
finger around the volume meter.
CineDash reacts on commands with a little “lag”, if you use it carefully you can expect no problems, but for nonchalant usage CineDash will not react on every touch. You also have to make sure that it's turned on for it to work.
Jul 21, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Computers & Internet Logo
430 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
