Question about Panasonic Lumix DMC-LZ5 Digital Camera
I slipped near the waters edge and the camera hit the water and partially submerged. Hasn't worke since. Camera turns on but thats about it. No zoom, no preview photos, no taking pictures, no picture on screen. Help! Damaged last Sunday.
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
The camera got pushed into a water dish. It got wet (probably partially submerged for a few hours)The photo chip played after being submerged.
If the water was clean and no one tried to switch it on while it was wet you have a chance.
The batteries should be removed as soon as it was discovered wet. The rice is a good idea but be aware it takes days and not hours. I use the airing cupboard and leave them at least a couple of weeks.
Mar 13, 2018 | bag Cameras
What can I do to turn on my digital camera after it was submerged in water?
First of all you should get (or have gotten) the battery out as soon as possible. You could try shaking excess water out of it. You should then put it in rice to draw all the moisture out of the camera. This may take a couple of days, maybe exchange with more dry rice after first day. When you are relatively sure all moisture is gone try reinstalling the battery. I will guess that you will only have a 20% chance of it ever working again.
Dec 21, 2011 | Canon Cameras
Samsung pl201 the zoom isn't working and stopping the camera from working normally. it says to take out the battery and try again. this hasn't worked.
Jul 17, 2011 | Samsung PL120 Digital Camera
I have a no connection message on my camera. its been in the water once but worked after we got out the pool. then it was turned on again and the message came up. i plugged it in my mac and the pictures...
If your camera was submerged, it's likely that corrosion has commenced within the camera. I'm sorry to say that nearly all cameras that have suffered water damage are unrepairable as corrosion strikes at many points within the camera. However the memory card is much more durable. Remove it from the camera. Consider purchasing an inexpensive card reader to use with your computer to download your photos from it.
Dec 30, 2010 | Cameras
Dropped my camera into a river was submerged for about 3 sec , but it did not actually hit any thing , was in my hand all the time . I took out the card and battery , next day I turned it on it came on...
Hello
The best thing you could do after this would have been to submerge the camera in distilled water and then open it up and dry everything.
The problem is that since the river water conducts electricity , there has probably been a short ciruit in the camera when you switched it on. This could have damaged any number of components inside and it will probably cost (depending on what camera you own) upwards of $200 to have it fixed so it may not be worth your while.
The lens is also a hit or miss. If it's a fully mechanical lens with no electronic components , I would send it away to have it professionally opened and cleaned. If it's a automatic lens , this may cost considerably more as they will probably have to replace the driving motors and electronics. I would put a clean and repair at about $150-$250.
All and all , it may well not be worth it and you could try selling the camera on e-bay as damaged for when someone needs some parts. You should be able to get a few bucks for it but don't count on too much.
Kind Regards
Andrea
Sep 27, 2010 | Canon Cameras
My olympus 1040 was dropped in water for a few seconds,i dried it out and now it will turn on but screen is blank,is there anything i can do or is it only fit for the bin..........
Solution: The most important thing to remember if your digital camera should be partially or fully submerged in water is to act quickly. Once your camera is out of the water, avoid the urge to turn the camera on to see if it works and instead remove the batteries immediately to prevent shorting any of the internal electrical components. Remove your memory card also, otherwise you may lose the pictures you’ve already taken and saved to the card.
Leaving the battery and memory card compartments open, dab away any excess water with a dry cloth or paper towel. Then, use a household hairdryer set to the lowest heat or no-heat setting and blow dry the camera for 10 to 15 minutes.
Although the outside of the camera may be dry, it’s what’s on the inside that counts. If any moisture is left within the camera, it may, over time, grow mold, which can interfere with the camera’s operation. If the camera was dropped into a chlorinated swimming pool or a saltwater lake, your camera’s components may suffer corrosion over time, and your camera will eventually stop working.
To help draw moisture out of the camera, pack your camera in a bowl filled with silica gel (the packets of small transparent beads often found in various foods, electronics, and clothing packages) or uncooked rice. Both materials can absorb and hold excess water that may be left in your camera. Leave your camera to dry for at least 24 to 48 hours. Once you are certain that your camera has completely dried out, insert fully charged batteries and press the Power button. With any luck, your camera will function properly. If not, you may try contacting a camera repair company to ask advice or inquire about repair options.
Jun 26, 2010 | Olympus Stylus / mju 1040 Digital Camera
Olympus SW 790 won't turn on after hitting the water.
Water and camera do not mix, water corrodes electrical contacts. I would suggest if you are taking a camera around water to buy one of the new water proof camera. Also salt water contact on a camera is like an acid bath. All major camera manufactures repair shops will not repair water damage.
Jul 02, 2009 | Olympus Mju 790 SW Digital Camera
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-LZ5 Digital Camera Logo
132 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
