Question about Sony Cyber-shot DSC-W55 Digital Camera
"Turn the power off and on again"
I'm having the same problem...I turn my camera on and it says "access" while the lens is going in and out and finally says "turn the power off and on again". I have used the compressed air and tapped it on my palm many times and it's still not working. I went on vacation in Jamaica and I think maybe some sand got into it or a little bit of water. Is it worth paying the money to get it fixed (had it for 2 years) or should I just get another camera? Any other suggestions about how to fix it myself?
I had the same problem and did like one of the solutions above suggested and just flicked the bottom of the lens and it worked. Mine is great again.
Posted on Aug 12, 2009
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
It turn the power on and on again and nothing happens
This is a common problem for all Sony Cybershot digital cameras. It is saying the error "Access" because whenever you turn it on, the camera finds it hard to retract and open out the lens. Chances are, there is some sand or maybe dust or dirt of These are few things you can do.
You can blow a compressed air on the camera's lens to try to take off the dirt or granule of sand stuck within the lens. Also, you can try to hold the camera from your right hand with the lens facing the ground and hit the camera's base on your left palm. Do this several times.
Let me know if this helped you. Goodluck!
Sep 16, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony Cyper-shot 7.2 digital camera - the lens will not open all the way, it makes noises when I turn it on like it's stuck and it says Access and then to turn the power off and on again. Nothing is...
Hi, The message "Turn off the power and on again" appears when the lens block assembly start malfunctioning, Therefore you have to replace the lens block assembly. Thanks for using fixya.
Jun 08, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Getting access
Was your unit dropped, or maybe left with the lens protruding? Seems you have a problem with the lens assy(stucked), during start-up, it will initialize to check if all systems go, if not then it will display turn off and on again. thanks
Sep 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
266 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
