Question about Minolta Office Equipment & Supplies
Minolta EP5420 not operating
I turn power on ,copier codes "malfunction detected Cd" Call for technical service and state code.
    President:
  • Minolta Master
  • 990 Answers
Hello sir; The error code you display "Cd" it means the duplex unit have problem, check with duplex unit , see wherre got paper jam , need roller to replace.
Posted on Jul 31, 2009
Erorr code po7
->Turned off printer
->Press STOP / RESET and hold, then press and hold the POWER button.
->While POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
->Release both buttons simultaneously.
->The computer will detect a NEW DEVICE, Ignore it .....
->This situation indicates the printer which Error P07 is in a state SERVICE MODE and ready to reset with software.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Apr 08, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
A Malfunction was detected. Please call your technical representative and provide code. C4553
CAUSE: Failed laser unit (C4551 - Cyan; C4552 - Magenta; C4553 - Yellow; C4554 - Black).
SOLUTION: To confirm the failure of one of the laser units, perform the following:
1. Power the copier OFF and remove the power cord from the wall.
2. Switch the position of the laser unit with one of the other laser units.
3. Plug in the power cord and power the copier ON.
4. The failure code should change dependent upon the new location. Replace the laser unit as necessary.
Jul 24, 2012 | Minolta Di251 All-In-One Printer
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Printer says "Malfunction detected Please call
What code is showing? and what model are we talking about?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 04, 2011 | Minolta Office Equipment & Supplies
Whenever i try to photocopy it states that malfunction was detected please call your technical representative and provide code...........cof32
What is the MAKE & MODEL? I'm guessing you have a Minolta??? You need to clean the drum unit & the ATDC sensor or replace the OPC
Sep 15, 2010 | Office Equipment & Supplies
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
