Question about Canon PIXMA iP1300 Printer
I have installed the new magenta ink and it still only prints yellow, green and blue. How do I get it to print with all colors?
    New Friend:
  • 63 Answers
A clogged head will overflow into the adjacent head. I have gone through several pixma printers because I used inexpensive, but inferior aftermarket inks. I learned the hard way to use only genuine Canon ink. For some reason, Canon printers are more sensitive to aftermarket ink than other brands.
Try soaking the print head in a solution of water and alcohol in a jewelry cleaner or laboratory sonicator
Posted on Aug 01, 2009
The colors do not print correctly.everything is blue/green/yellow. the ink cartridges are new. black prints fine. the troubleshooting optin only lets me select to remove lines, it wont let me adjust the...
The magenta cartridge isn't working correctly. This is why you're only getting the other colors (blue is cyan, green is cyan and yellow, and then yellow).
Try removing and reseating the magenta cartridge. If that doesn't work, use a new magenta cartridge (the cartridge itself may have been defective).
I wasn't able to view a manual for this machine, as it's been discontinued and Lexmark no longer offers the PDF on it. If you have a "clean print heads" option, use it. It may require more than one try. If you don't have that option, then all possibilities have been covered.
Hope that's helpful.
Jan 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Printing is way to light
if your prints are coming out with blue green tint, more than likely, the magenta (pink) is missing from your calibration page. Print out a calibration sheet, you should have black, yellow, blue, and magenta. If one of these colors is missing, your printhead is clogged. You need a new one. Call Kodak Tech Support.
Oct 03, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
C88 only green and yellow
You are out of black and magenta (tricolor cartridge) ink or ink has dried up.
Try touching the nozzle plate (underneath print cartridge) with a water dampened cloth (not alcohol) for cleaning clogged nozzles (do not rub).
Ultimate remedy : put in contact nozzle plate with hot water for about 5 seconds.
If color still missing your printer need new cartridges.
Jan 06, 2008 | Epson Stylus C88 InkJet Photo Printer
Canon PIXMA iP1300 Printer Logo
163 people viewed this question
old marine
old marine
