Press and release Time. Press and release each number of the time: if the time is less than 10:00, start with a 0, otherwise start with 1. Press and release the PM button if it is afternoon. Press and release Enter. Press and release Alarm, then press and release Time to confirm it is set.
(Took me forever to figure this thing out)
SOURCE: alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: How do I set the alarm time on GE Model 7-4813B
On the top left front, hold down the "WAKE" button and at the same time tap or hold the "HOUR" button and then the "MIN" button until the wake-up time is showwing--then release the "WAKE" button. Note that the AM light comes on to the left of the display hour, or is OFF for PM times. Larry K
