Question about Microwave Ovens
My Whirlpool microwave is not heating. The light, turntable and fan is working. What is my next step? model MH2175SXQ-0
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Jul 31, 2009
Fan not working on Whirlpool microwave Model MH2175xss1
What do you mean "fan doesn't work"? Magnetron will over heat without fan.
Apr 26, 2017 | Whirlpool Microwave Ovens
My 5 yr old Whirlpool microwave stopped heating food. All other lights, displays, fan and turntable work. What could be the trouble?
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...). Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board.
Dado
Jun 09, 2015 | Whirlpool Microwave Ovens
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
All leds, timer, fan etc working but microwave will hot even heat water. Control panel, turntable and light inside oven works also.
The problem is one of three things, the magnetron is defective "common issue" or the high voltage capacitor and diode may be a factor, repairs could be close to a new microwave oven.
Feb 20, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
The microwave heats and the clock/timer works, but the light, fan and turntable do not. Is this the fuse?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gkjgkj
Jun 26, 2010 | Whirlpool MT3130SH Microwave Oven
Oven does not heat food.
either the h.v. diode,h.v. capacitor or the magnetron tube are suspect here due to the no heat condition you have
Oct 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool Model #MH1170XSS-0 will not heat
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit and your symptoms, as well as the answer to the following questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 07, 2009 | Whirlpool Microwave Ovens
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
Microwave Ovens Logo
153 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
