Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Wheres the ethernet card at on my dell - Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
  • 1,511 Answers
You can't see the Ethernet Card as such because it is In-Built in the Board of the Machine. There will be a chipset embedded on the Main board, controlling the Ethernet card operations.
You can see the Full specs of you Machine Here
Regards.
Posted on Jul 31, 2009
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
This is Dell Support >XPS 400 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
http://support.dell.com/support/edocs/systems/xps400/sm/techov.htm#wp1053398
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675156&CatId=200
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
http://support.dell.com/support/edocs/systems/xps400/sm/about.htm#wp1053567
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
Can't plug ethernet cable from modem into dell
You will need to get a PCI ethernet card and install it.
Your computer doesn't have an ethernet connection on the motherboard.
Nov 23, 2009 | Dell Computers & Internet
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Bad network card in a Dell Dimension 8200. What
You can purchase ethernet card "realtelk ethernet lan card "
Realtelk is best network card right now.
Also Dlink network card is also good.
Jul 24, 2009 | Dell Dimension 8200 PC Desktop
Dell ethernet card
You must buy a pci spec'ed Ethernet care. This will fit into the white socket on the system worse case you go buy a USB based ethernet adapter.
Mar 19, 2009 | Dell Ethernet Card Network Adapter
Can anyone tell me how to uninstall ethernet card in dell optiplex 320? I also need to know where to download and install the ethernet card. I can't go to ipconfig and see my ip address. The tech sup...
The ethernet card on the Dell Optiplex 320 is integrated into the motherboard and can not be physically removed. However, a new ethernet card could still be installed into one of the available PCI slots and can be purchased at just about any computer parts retailer.
Before you jump to replacing the card I would recommend trying a few things yourself to fix the card. Here are some suggestions:
One thing to try is disabling and then re-enabling the device through the device manager.
Another thing to try, go to the command prompt where you did the ipconfig, and type
IPCONFIG /release
then type
IPCONFIG /Renew
Those two commands have fixed many "dead" ethernet cards.
If those commands don't work and fix your problem I recommend giving this utility a try:
WinSock XP Fix
Does the computer recognize that there is an ethernet card in the system? Have you had any viruses or spyware/malware on the machine recently?
Mar 17, 2009 | Dell OptiPlex GX260 PC Desktop
Do I have an ethernet card?
Yes, Intel Pro/1000 is gigabit ethernet, which will do 100Mbps and 10Mbps too.
This will be compatable with your broadband requirements.
Feb 20, 2009 | Dell Ethernet Card Network Adapter
Ethernet card
Just go to this website and have the dowloading there:
www.nvdia.com and make sure you follow the installation very carefully.
I hope this will help you.
You are welcome
Please, rate this Solution.
Oct 16, 2008 | Computers & Internet
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
