Question about Acer Aspire 3000 Notebook
Wont boot the laptop wont open pass the window logo with the black screen but i can boot into safe mode, net searching sugested it was a program that windows starts with, but i uncheck all the program that starts with window and still wont boot .Maybe its a harware issue but is there a way to be sure sure , pls help thanks , Sylvie
  • Sylvie 1101 Nov 26, 2007
    First i wanna say thanks for helping ,i've tried everything possible ,even disabling ,one by one ALMOST ALL the drivers altough not sure that's what i should ove done , ok the last prog. i can thing was installed was some music player (i was not the one that had installed it ) but i had already removed it one other program that gave me a prob. with updates was i tune and i can not remove this prog in safe mode but removing the other music thing did not resolve it .
  • 116 Answers
In this industry it is always a hardware or software. But if your PC does not allow you to get into windows without going into safe mode it was probably due to a bad driver installed, but you must determine that driver. So look into your mind and find out what you loaded last onto your pc with drivers. If you can remember delete that from your system while in safe mode. But only if you remember do not speculate. In order to remove software you need to get into control panel
Click on start
Then locate Control Panel
Then locate Add/remove software
Locate the software you recently put on your computer
Unistall it
Reboot PC
This will hopefully fix the problem!
In my experience usually a reload of the OS and all program fixes this problem, the other fix is by shear luck you find the right software to remove it.
Reinstalling OS and programs is really simple. First try the software removal if this does not help contact me I will walk you through OS reinstall!
Posted on Nov 26, 2007
Asus x553m laptop wont turn on fully?
Just before it tries to start windows, go to safe mode, press F8 and select safe mode, you may need an external keyboard. That will enable you to restore the faulty/damaged files.
Jun 14, 2016 | ASUS Computers & Internet
Wont boot bios windows
Try pressing F8 while the laptop is booting and select "safe mode". If it boots fine in safe mode, it might be either driver issue or the laptop's videocard giving up. The driver issue is corrected by installing the right drivers, you can ensure if the problem is on the hardware side by setting it to boot in 640*480*256 (or lowest possible resolution) and see if it boots. Also, try pressing F8 during boot and select the option to log the boot process. The log file might then tell you what causes the stop/hang.
Oct 23, 2013 | Acer Aspire 5738Z-423G32Mn Notebook
Wont start i go to safe moode it dont work f11 asking for pass word
Which operating system ????.....
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Oct 14, 2013 | Medion M3 Composer 5100 PC Desktop
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1 for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Support for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
Fujitsu scaleo j wont load passed the fujitsu siemans logo screen
If you remove the Graphic Card and replace the original Memory will it boot?
Jan 28, 2013 | Computers & Internet
I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
Wont load passed windows xp screen
Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
May 10, 2009 | Computers & Internet
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Acer Aspire 3000 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
