Question about HP Officejet 6310 All-In-One InkJet Printer
HP brand Ink running out too quickly.
I had just installed a new HP cartridge (black) on 7/15. Only about 25 faxed sheets were received since then and we only use it as a fax. I read somewhere that you can adjust the amount of ink used on the computer but it's not hooked up as a computer printer. Any suggestions?
  • 108 Answers
Check to see if there is an econo option to save ink. also if these faxes have alot of solid ink or pictures on them, they will use up alot of ink.
Posted on Jul 31, 2009
Near empty black is displayed even with new black cartridge
If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2.
WARNING
If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned.
If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter.
If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are
installed properly.
Jan 01, 2011 | Brother IntelliFAX-2440c Plain Paper...
I just loaded new HP 94 and HP 97 ink cartridges in my HP 6210 Officejet. I went through the alignment process and received a sheet that had colors, but no black ink. The printout indicated the alignment...
Make sure all the protective tape on the Black cartridge has been removed. Also are the inks re-filled? I have seen many re-filled cartridges fail in a similar maner.
Nov 22, 2010 | Computers & Internet
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
My mother's Presto Printer ink cartridge runs out about every 20 days. She only received about four TEXT pages per day, no photos. What's the deal?
That is surprising. However, the TriColor ink cartridge makes black by mixing the three inks. This is much easier for an elder to change by themselves than a two-cartridge system, but it does run out a bit more quickly. Be sure you use the HP97 ink cartridge. It has twice the ink volume (14 ml) for only 1.5 times the price. And, the original equipment ink cartridges go a lot farther than the cheap non-HP refills. Plus, the HP brand cartridges are the only ones that will report ink level up to the PrestoConnect account manager website. In the end, even a new cartridge every 20 days is WAY cheaper than a computer, software and broadband. And the joy the elder gets from being connected to family is priceless. Hope that helps.
Sep 29, 2009 | Presto Printing Mailbox Printer for ...
The faxes coming through are blank pages, I received faxes yesterday but today they are coming through blank and the ink cartridge is brand new.
take the cartridge out and dab it on a paper towel - there should be a dark black solid rectangle of ink - if not the printhead is dry or blocked - if it is dry soak the printhead( the place the ink comes out) in a dish of warm water for 2 or three minutes and try blotting again - if that doesnt solve your problem take the cartridge back to the retailer or refill store you got it from
Jul 15, 2009 | HP Office Equipment & Supplies
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
I have the c6100 all in one series. I can't copy or fax anything . I change the black ink cartride. I have an error message . Ink system has failed 0xc18a0306
"c6100" what brand? HP I guess. Well I suppose you set the printer to see the black cartridge as a new one! What light blinks? You might have to change the collor cartridge too! try that! For how long do you have the printer? It may have a full residual ink memory issue!
Nov 15, 2008 | HP Office Equipment & Supplies
Installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Dec 03, 2007 | HP 1040 Plain Paper Inkjet Fax
HP Officejet 6310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
