Question about Canon BubbleJet Office Equipment & Supplies
My canon bjc4400 printer won't turn on, Help!!
I've changed the power cable and I've plugged into a different power socket.
SOURCE:
  • 279 Answers
SOURCE: head stops in the middle and light flashes
That's the behavior of a printer that is missing its ink cartridge. It is possible there's a fault with your ink cartridge. Try replacing it and see if it works.
Posted on Aug 28, 2007
komguy
  • 2306 Answers
SOURCE: after power surge, canon I9900 printer will not turn on?
You can try to power up with the printhead out, that sometimes causes it to not power up. Otherwise that machine is fried since you can't get a replacement logic pcb anymore.
Posted on Jul 30, 2009
  • 415 Answers
SOURCE: My area recently had a
Unfortunatey if you've turned it off and on by trying different outlets and it's still not turning on it sounds like a power surge took out your printer. Often it is as cheap to replace the printer than to have someone fix it...
Posted on Jun 25, 2011
  • 68 Answers
SOURCE: My acer aspire x1200 won't
Sounds like a power supply problem, not uncommon for that model. Luckily they're fairly easy to replace... usually.
http://www.google.com/search?rlz=1C1CHKZ_enUS430US430&sourceid=chrome&ie=UTF-8&q=aspire+x1200#sclient=psy&hl=en&authuser=0&rlz=1C1CHKZ_enUS430US430&tbm=shop&source=hp&q=aspire+x1200+power+supply&pbx=1&oq=aspire+x1200+power+supply&aq=f&aqi=&aql=undefined&gs_sm=e&gs_upl=33106l33666l1l2l2l0l0l0l0l171l282l0.2l2&bav=on.2,or.r_gc.r_pw.&fp=11627066b9f80862&biw=1301&bih=831
You might be able to get a generic power supply in there, but you want to make sure it fits and the screw holes line up!
Posted on Jun 27, 2011
ankitchandel
  • 141 Answers
SOURCE: my canon pixma MP520 won't turn on
check your power supply...
Posted on Feb 09, 2012
What should I do to fix my canon mg7120 printer when I get the message "printer not responding"?
check that the printer is "on", and that it's actually connected. Change USB cable for another one, plug into a different USB socket on computer. If no help, try on another computer.
Sep 02, 2014 | Canon PIXMA MG7120 Wireless Color...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My area recently had a power failure. Oddly, during the power failure I could still see a light coming from the Canon MG5220 printer. After power was restored, it was sometime later when I noticed that...
Unfortunately, it sounds like when the power was restored, the printer experienced a surge. If this was not plugged into a surge protector, then it's possible the switch was fried at the point of power restoration. It is important that with units such as printers, monitors, towers (computer), tv's, vcr/dvd players, almost any type of electrical appliance be plugged into a surge protector. However, even if this was true in this case - when a power shortage (outage) is experienced, it is necessary to unplug everything so that when the power is restored, nothing that is plugged in will be affected; as your printer was.
Now, you can have this fixed - either take it to a local computer repair shop; that might be able to fix it, or contact the manufacturer and inquire about sending the unit in for repair - regardless of warranty or not. If it is still under warranty, they may honor it. I am not positive they will for an accidental damage such as this, but it's worth calling them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 25, 2011 | Canon Pixma MG5220 InkJet Printer
Pixma 810: Suddenly the printer is dead. Despite power cable is connected with Pixma I can no longer turn the printer on. Is there a fuse anywhere? What is the solution? Best regards Peter Widmer
Hi
First of all please make sure that all the cables from/to the printer are connected properly. Now please use different power socket to make sure that the printer is getting power. If so then we can reset the printer. To reset the printer unplug it from/to the power socket and mains and let it sit without power for more then 10 minutes and then replace all the cables and print a test page. If still the issue is not resolved then you'll need to replace the printer cable. Hope this helps...please post back for further assistance.
Daniel
May 19, 2011 | Canon PIXMA MP810 All-In-One InkJet...
How toPull Canon i860 Cartridge Holder Manually to the Center.
Hmmmmm. Well, you could power the printer on, open the lid so that the cartridge caddy moves to the center, then pull the power plug...? Beyond that, I've never tried what you're fixing to try.
Nov 11, 2009 | Canon i860 InkJet Photo Printer
Clicking sound and in use/memory light flashes. Canon PIXMA MX850
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
Jul 13, 2009 | Canon Office Equipment & Supplies
My Canon PIXMA iP4000 will not turn on. Printer was working great until i went to turn it on and there was no power.
Dear Mmally1323,
You said "My Canon PIXMA iP4000 will not turn on. Printer was working great until i went to turn it on and there was no power."
First off make sure that your powre cable is securely plugged into your printer and into the wall. If the printer still doesnt turn on then try to plug it into a different wall socket, as the socket could be 'dead'.
Jul 02, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Open Questions:
Clive
Clive
old marine
old marine
