Question about Craftsman Garden
I have a crftmans rider ltx 1000 , i was cutting the lawn picked up a cable which wraped itself arouf the mandrels for the blades and stopped the mower , got cable removed started right up no problem , engaged blades and yikes a real bad vibration , so i ordered both mandrels replaced them still there put on new blades still there relaced the pulley on the bottom of engine still there can you tell me where to go from here ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Yes, if you jammed something in the blades and the belt stopped, the engine pulley wore a thin spot in the belt.Every time that thin spot runs around a pulley it rides deeper in the pulley making it vibrate.Take the belt off and you should be able to see or feel the spot where the engine pulley burnt it. Replace the belt and it should fix it.
Posted on Jul 31, 2009
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
I replaed the blade drive mandrel and reattacheed the blade and the blade does not freelyturn t is so bound up tht I cannot turnit manually
okay check see if brakes is on the mower, not the tractor but the blades of the mower deck if not then take belt off of the new mandrel side and try turning blade by hand. should turn freely if not mandrel is bad but unlikely. sounds like you changed wrong side mandrel I presume you have 2 blades and mandrels. or when you installed it back on. the belt may be bound up between a guide and pulley just kind of look things over before a tear apart. and then do your tear apart one step at a time then check blade to see if it turns does not seem serious you may have put belt on wrong, I have done it my self. hope this helps major note do not do this with engine running cut you hand off in a flash.
Aug 13, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Ltx
Contact mtd.com help desk. Tech help can get you to the right parts to make needed repair. Most likely it is your blade spindle assembly that has been bent allowing belt to slip. It is not that diifcult to replace.
Jul 18, 2014 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
One blade cuts and one doesn't. Is this a pulley or a belt problem?drive belt sound hasn't changed. can belts be adjusted or only replaced? what tools are needed?
Set the thing up on some blocks and try to remove the blade which does not turn. Since your belt is working, the pulley must be spinning or there would briefly be an awful racket. If the pulley is spinning but the blade is not then there is something wrong with the mandrel/spindle, or the blade has come loose and has somehow not cut off anyone's foot. Sometimes the pulley and top of the mandrel become rounded out but again there would be some metal on metal noise. Often there is a star shaped protrusion on the bottom of the mandrel which locks into the blade and by virtue of hitting some immovable object, that unstoppable keeper has been destroyed.
Jun 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
May 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Deck is leveled, blades are fine,spindle not bent it still cuts
there was a problem with the lighter gauge decks [thinner steel], and the deck would actually bend inward on the left side. this would tilt the mandrel inward making the blade cut at a slight angle to the right blade - there is tool to straighten the deck [the left mandrel housing usually breaks, though] - some shops have this tool, others have never heard of such a thing - most sears l&g field techs have this tool in their trucks - i have the tool in my shop, but i have had luck with turning the deck over and whapping it a couple of times on the inside edge of the left mandrel until the blades line up
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
185 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
