Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer front load and its giving me a message of dl f. I can hear it trying to click but nothing happens.
    President:
  • 1,776 Answers
This should indicate a door lock error and the clicking is the door trying to lock. The door is supposed to attempt to lock six times before the dl error is displayed. It is most likely caused by a faulty door lock switch. Hope this helped and best wishes.
Posted on Jul 31, 2009
Whirlpool duet washer dl light on but nothing happens when i press the cancel button or any button on the panel> i umplugged the machine thinking that it would reset but no change
'dl' on Whirlpool washers normally indicates there is a problem with the Door Lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. It will not reset. Sorry- Service call!
John C
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer has an F dl problem?
Fdl is a code that indicates a door lock error. The clicking sound that you hear is most likely the door lock. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Jun 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet problem with door lock
I've had this same exact problem and that's why I'm at this site.   I have had success with holding the start button and hitting the door right over the place where the switch is on the other side.  That worked good until today so I've called a service tech to come out later this week.  Give that a try and maybe it will work for you.
Oct 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
234 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
