Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
    Scholar:
  • 117 Answers
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Posted on Jul 31, 2009
Freezer is dripping water into the bottom of the freezer and causing sheets of ice to build up in the bottom of the freezer compartment. It is a Frigidaire Gallery side by side.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer side of a side by side water in the bottom
the drain is clogged.take a hair dryer and un thaw the drain
Dec 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Build Up in Freezer of FRS26ZSH
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Jul 23, 2009 | Frigidaire FRS26R4A Side by Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaks onto floor
your defrost drain is stopedup if its a sxs its in the back bottom of freezer side if its a top mount its behind the back over in the freezer remove and use hot water and blowdryer you will see a little drain tube under the evap coil
Jul 05, 2009 | Frigidaire Gallery Series GLRT218WDZ 30"...
There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Mar 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRS26ZSH freezer leaking
Plz provide me with a e mail adres so i can foward a users manual to you for a Frigidaire FRS26ZSH.
Thanks.
Wouter....
Aug 31, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
837 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
