I have been having problems with my 2003 chevy tahoe lt. it has been shutting down evey so often while turning(only) ive changed the battery, sparks, and the alternator and nothing seems to be working. has anybody has this problem before if so whats the solution?
Question edited for clarity and spelling. No Cadillacs in the exhaust!
Question moved from Cadillac Cars to Chevy Tahoe.
Yes of course. Those sensors meter the flow of gas to the engine. With no data coming back to the Engine Control Unit, the car shuts off. You need to replace the Catalytic converters and replace both upstream and downstream sensors. Get down the Scrap Yard and see if you can find yours!
Hello. Yes, your Chevrolet's security system will 'shut-down' the ignition system; causing your truck to start but stop instantly. The truck 'thinks' it is being 'stolen' and will 'enable' it's security system to 'hamper' stealing it. Good luck and keep me informed; if you want to.
Turn your key to the on position(do not start), then push the throttle pedal to the floor three times, turn of the ignition, wait a second or twothen start the engine, this should reset it. Works on the 2000 Tahoe LT 4WD
first we need to find out what three cylinders and what is not working about them, no compression, too much leak down, or no spark? find out and i will try and help
replace fuel pump relay. check all fuses to ignition and pcm .make sure they are not loose. check coil wires make sure they not loose.look at battery if you have the ac delco seal battery make sure green eye still there .if its black have battery check out.
