Thanks so much for any help with this, sarah
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
SOURCE: No auxiliary source option kdc-mp 235
i have a kdc 135 and i had the same problem. you have to go to standby mode, then hold down the menu button until MENU appears. then toggle up or down with the button on the right and it will say aux. then toggle left or right to turn aux on/off and then after that when you hit source it will come up as an option.
if the phone is a model q9c then the code is 000000 if it is a model qa30 then code is the last 4 numbers of your phone number
SOURCE: Hi, I tried setting up my TV last night and all I
You must check your input signal...how is signal being sent to your' TV....set TV to THAT input type
SOURCE: lg 50pm4700 will not connet to the internet
I had a similiar problem and found a solution! :) im passing on my joy to you. Try getting a USB extension or just wrapping foil around the Dongle. It seems that the dongle or the TV causes interference of some sort to cause the tv to drop the internet. ON my tv it would say connected to the net sometimes but as soon as id try netcast it would drop. As soon as i got the extension it went away. At least try the foil thing. Wrap it like a Dog cone for injured dogs.
