Cars & Trucks Logo
J
John Zimbizi Posted on Mar 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Torque specification for renalt scenic cylinder herad
Justin H. Reed
Level 2:
Sergeant:
  • Cars & Trucks Expert 317 Answers
  • Posted on Mar 26, 2018
Justin H. Reed
Level 2:
Sergeant:
Answers
317
Questions
0
Helped
111360
Points
670
Hi. Thanks for your question. For assistance on torqu specification for rnault scenic cylinder heard you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 25, 2008
SOURCE: 2003 renault scenic
its your own fault for buying froggy,nothing but electrical faults on renaults and it dealer only as software encrypted and only dealer has digital signature to connect into renault main frame and diagnose and reprogramme the car
Anonymous
  • 104 Answers
  • Posted on Jan 03, 2009
SOURCE: TORQUE SETTINGS ISUZU RODEO FOUR CYLINDER
I dont know the specific answer for your question, but I own a 1995 Rodeo and there is an online community you could probably check out that Im sure would have the answer for you.
Check out www.planetisuzoo.com, sign up and post your question there. There are several knowledgeable people there and some good information as well.
Anonymous
  • Posted on Jan 31, 2009
SOURCE: torque specifications for cylinder head
you need to be more specific...what make of vehicle you working on and engine size
Anonymous
  • 124 Answers
  • Posted on Oct 17, 2009
SOURCE: fual want go into the engin on my renalt
hi,
I had the same problem.
The fuel filter located under the fuel tank can sometimes block.
What you could do is carefully disconnect the fuel line on the injector rail and have someone turn on the ignition to see if you are getting fuel in there if you are then its not the fuel filter or the pump
steve_e_uk
steve morris
  • 1675 Answers
  • Posted on Feb 26, 2010
SOURCE: how do you put codes into the radio cd player for
hi what you is supply the make of it ie phillips, sony, that sort of thing and the serial number on the head unit then i might be able to help with a code, although, if you have imputed the code incorrectly 3 or more times the radio will become locked out and be unusable as this is an anti theft thing to make it unsaleable to thieves....if you have not put it in 3 or more times then we can see if i can supply a code for you
What are the talk torque settings on Kia 2.7 j2 engine cylinder head
I apologize, but I don't have access to specific torque specifications for every engine and vehicle. The torque specifications for the cylinder head bolts on a Kia 2.7L J2 engine may vary depending on the specific model and year of the vehicle. It is crucial to refer to the manufacturer's service manual or consult with a certified Kia mechanic to obtain the correct and up-to-date torque specifications for your particular engine.
The service manual will provide the recommended torque values, as well as the specific sequence for tightening the cylinder head bolts. Following the manufacturer's specifications is important to ensure proper sealing and avoid any damage to the engine components.
1helpful
Torque settings for Tata 709 EX Turbo
The torque settings for the 4 cylinder engine on a Tata 709 EX Turbo will depend on the specific model and year of your vehicle, as well as the type of engine you have. Tata Motors provides specific torque specifications for each of their vehicles in their service manuals, which can be obtained from a Tata Motors dealership or service center.
Here are the general torque settings for a Tata 709 EX Turbo with a 4 cylinder engine:
  • Cylinder head bolts: 80-85 Nm
  • Connecting rod bolts: 55-60 Nm
  • Main bearing bolts: 80-85 Nm
  • Flywheel bolts: 65-70 Nm
  • Oil pump bolts: 15-20 Nm
  • Oil pan bolts: 10-15 Nm
  • Oil cooler bolts: 10-15 Nm
Note: These torque settings are provided for reference only, and may not be applicable to your specific vehicle. Always refer to the service manual for your vehicle to obtain the correct torque settings. Improperly tightened bolts or fasteners can lead to engine damage or failure, so it is important to follow the torque specifications provided by the manufacturer.
What is the torque pounds for a 2003 v Star 1100 head bolts
Details here on Page 94
11. Following the tightening sequence shown in
Figure 15, torque the fasteners in 1/2 turn increments and in two stages to the specifications.
Torque the fasteners to 1/2 the given torque, then
torque them to their final specifications:
a. Cylinder head nuts (1-4, Figure 15): 50 N•m
(37 ft.-lb.).
b. Cylinder head cap nut (5, Figure 15): 35 N•m
(26 ft.-lb.).
c. Cylinder head bolts (6 and 7, Figure 15): 20
N•m (15 ft.-lb.).
12. If the cylinder has also been reinstalled, torque
the cylinder bolts (A and B, Figure 23) to 10 N•m
(89 in.-lb.). One of the bolts sits in a recess (B, Fig-
ure 23) in the cylinder block.
13. If removed, install the locating pin (B, Figure
21) into the camshaft
Engine Lower End Torque Specifications - V star 1100
https://www.manualslib.com > ... > Owner's manual
Yamaha V star 1100 Manual Online: Engine Lower End Torque Specifications. Item N•m Alternator cover bolts 10 Connecting rod nuts 48 Crankcase stud 10 mm 20 ...
1helpful
My Renalt scenic 2003 1.6 16v automati just cutt off the engine and now its not starting but the engine is crenking?
You need fuel, spark and compression for an engine to run. You need to figure out what is missing and that will tell you where to look to fix your problem.
Torque specication for renalt scenic cylinder head
Hi. Thanks for your question. For specification for cylinder head on renault scenic you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Valve timming for renalt scenic
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
All the best
How to reset service light for renalt scenic
Press button on wiper stalk till service due comes up. Then press and hold button on wiper stalk
Apply a light coat of engine oil on the threads and
under the heads of the cylinder head bolts.
- Install the plate washer to each cylinder head
bolt.
- Using Torque wrench, install and uniformly tighten the ten
cylinder head bolts in several passes.
Torque: 60 N-m (610 kgf-cm, 44 ft-lbf)
Fual want go into the engin on my renalt
hi,
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
