Question about Kenmore Refrigerators
Ice machine I turned off water flow to the ice machine while on vacation. Upon returning and turning the water back on, the ice machince does not function. I do get water throught the door dispensor but no water flows into the ice making tray area.
  • dvonborstel Aug 03, 2009
    It turns out that ice had formed in the discharge hose into the ice machine. It was visible with a flashlight. A blow dry supplied enough heat to thaw the ice. I then manually filled the tray and when it dumped a little while longer, the machine fill on its own and everything is running fine.
    Scholar:
  • 117 Answers
More than likely the problem lies with the water valve. You have a double water valve on side/side and one of the solenoids are probably sticking. You may get it to start again by taking it apart ,cleaning or you may need a new water valve altogether. Hope this helps
Posted on Jul 31, 2009
Went on vacation without turning the ice maker off was gone for to 2 weeks and the ice maker was full upon our return. I emptied all the ice and now the ice maker is not working (not making ice). I would...
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Jul 08, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a digital thermostat that upon return from vacation the backlight is not lit and the functions don't work. The heater unit fan was on during the vacation and the only way to turn it off is to...
Batteries dead????? Most thermostats have batteries inside , replace them....is the Furnace switch/breaker on ??...Some thermostats use the furnace power to function
Oct 25, 2009 | Heating & Cooling
Ice maker has quit working
Sounds like the water port to the ice maker is frozen. Do a complete defrost - shut off power for at least a day or more then turn back on and see what happens.
Mar 25, 2009 | Refrigerators
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Not building pressue
Water damage to the flow meter can cause the machine to not function at all. We have seen water leaking from the water tank leaks right on the flow meter and stops the machine from heating and contining its start up proceedure.
Espresso machine Sales and Service.
www.CeriniCoffee.com
johnny@cerinicoffee.com
Sep 04, 2008 | Pasquini Livia 90 Espresso Machine
Ice maker not working
I am so sorry, but I believe that you are going to need a service call. It doesn't look like it is as simple as turning the water off for vacation. (Seems like nothing ever is!?)Take a look at this page
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=1171&p_created=1181072131&p_sid=GeUY8_bj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzQsMzQmcF9wcm9kcz0yNjkmcF9jYXRzPSZwX3B2PTEuMjY5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9aG93IHRvIHJlc3RhcnQgYWZ0ZXIgdmFjYXRpb24gd2F0ZXIgdHVybmVkIG9mZg**&p_li=&p_topview=1
And take a look on the site for the Customer Support option and you will be able to locate a service person near you. Good luck to you. and thank You for using FixYA!
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
