Question about LG Heating & Cooling
Set up Digitech AR1731 Remote control for a LG Invertor V air con
SOURCE:
bobotfel
  • 241 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 400 Answers
SOURCE: KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Posted on Mar 05, 2009
crouchdash
  • 83 Answers
SOURCE: I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
Posted on May 27, 2009
SOURCE: Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Posted on Aug 09, 2009
SOURCE: Fujita V-Lec Air con
i need a window kit for my air con
Posted on Mar 25, 2011
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Hi. I have a DL Air conditioning split system with a AR1731 Universal A-C Remote. The model air conditioning DL DSR-35G/E I am looking for code for the universal remote please.can you...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 17, 2014 | Televison & Video
What is the code for a Fujitsu ast9ashcw on a digitech ar 1731 remoe control?
Fujitsu Air Con codes for the Digitech AR1731 Universal Remote Control for Air Conditioners are:-
1152
0464
0127-0137
May 22, 2014 | Televison & Video
Remote codes for Fujiaire
Code for fujiaire 090
Jan 07, 2014 | Heating & Cooling
Digitech ar 1731 Air conditioner remote. I need code for Fujitsu AC Model AST12LSBCW please
1152
0464
0127-0137
Dec 12, 2013 | Televison & Video
My air con is quite new, it just fixed n used about 5-6 months. Today i just turn on the air con then about 5 second it turn off by itself. My air con is LG brand. How can i do now, is it a big problem or...
dear sir/madam
please check when you make on your air con it,s getting turn off from it,s circuit breaker then it,s an electrical short circuit problem if it,s turn off by it,s remote controller then it can be micro control program error.
if you know how to read to a electrical meter then try to check your electrical main source it,s passing electricity to air con and try to find out the problem
if not then try to contact to maintenance personnel. it,s up to you what you want to select option.
hope answer the question
thank you
please vote!
Sep 23, 2010 | LG Heating & Cooling
Just after basic programming for 8 in one
Rank:
0121 0222 0229 0235 0261
LG:
0404 0419 0383 0414 0296
Try the auto code search. Switch on the device > Select the device key to program > Hold the green "Set" button for 3 seconds > Press "OK" at "Setup" > press "OK" at "Code Se[t]" > Press the down arrow to highlight "Auto" > Press "OK" > Aim at the device > Hold the down arrow for 2 seconds > Press the "OK" button when the device powers off.
Oct 19, 2009 | Televison & Video
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
104 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
