Question about Sony KP-57HW40 57" Rear Projection Television
Help turns on blue screen then shuts off. 8 blinks
I have the same problem, the service man just left, he said it needs 3 new picture tubes. Est. cost $1200-1300.
He made a small ajustment, and it is working now, he said it could last 1 day to 2 years.
Posted on Nov 26, 2007
I have a 2000 Sony projection tv. When I turn it on it has a blue screen then it shuts off in around 5 seconds. The light on front keeps flashing 8 times in a row. Any ideas?
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
Consistently finding that as an answer. I would assume that is the part that is broken. The 8 blinks is an error code which points to this part being faulty.
Oct 24, 2012 | Televison & Video
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen turned orange, heard a sizzle sound tv
A capacitor has burned out. It may be on the motherboard or power supply.
Jul 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
8 Blinks; Sony KP65WS500
8 Blinks means problem with audio is making set go into protective shutdown Check Audio Amp IC406. You can also make this appear on your screen to show how many times this has occurred or if any other faults are present by pressing the following buttons DISPLAY,CHANNEL,5,VOL MINUS,Then POWER. Hope this helps if you need anything further let me know
Jan 08, 2008 | Sony KP-65WS500 65" Rear Projection...
KP-57HW40 w/ 8 Blinks
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
Dec 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
