Question about Ricoh Aficio SP C811DN-DL Printer
Ricoh printer full
Spc411 Ricoh
Same issue Standard tray is full and it is not
  • 108 Answers
The exit sensor might be dirty. also try turning the printer off waiting a few minutes then turn back on.
Posted on Jul 31, 2009
My printer Tray 1 won't close. How can I fix this problem?
Typically the issue with these types of printers is that the printers it's on the surface that is on even. Or something has got lodged between the back of the paper tray and this log back in.
Pull the paper tray completely out making sure the paper it's properly in the tray. Then look for parts that look like they are either band or out of place. Then look inside the tray slot to make sure there's no obstructions. If the printer tray is at the bottom of the printer be sure that there are nothing underneath the printer and it sitting on a hard surface.
Feb 24, 2016 | Ricoh Office Equipment & Supplies
I get remove paper standard tray on a AFICIO AP3800C and it locks up the software. Then does not allow clearing the message. I have removed paper. Tried Aux feed. Always does same thing
On the face down exit tray (one on top) there should be a 3 or 4 inch long plastic part sticking straight out and pointed down. That is the tray full sensor arm. It could be knocked out of the holder and now working right.
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Problem Ricoh cl 5000
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Ricoh Aficio CL5000 Laser Printer
Ricoh SPC411 DN Error
dirty ID sensors on transfer belt clean with canned air or replace. Careful not to spray liquid freon on transfer belt or you will replace that too!
Sep 18, 2008 | Ricoh Aficio SP C411DN Laser Printer
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
161 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
