Question about Rainbow Vacuums
When I turned on the vacuum it started to smell
I have a Rainbow E Series and when I turned it on, it started to smell like something electrical was burning.
    Scholar:
  • 114 Answers
You did not say if the vacuum ran and started to stink after running for a while. If this is the case, it's usually time for new brushes and a motor cleanup.
Posted on Dec 21, 2009
  • 40 Answers
The vacuum is either shorting or the motor or brush assembly is rubbing something.
Posted on Jul 31, 2009
RAINBOW E SERIES REPAIR MANUAL
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Mar 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Problem with E series rainbow, motor starts then slows down to a halt and smells.
From what you describe, you will probably have to replace the motor. But you could take it apart and see if it just needs carbon brushes.
Mar 25, 2008 | Vacuums
Rainbow e series
It could if the separator is binding, or dragging, when it turns, causing the motor to over heat, that maybe what you are smelling. If it is, then replace the separator.
Dec 29, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
485 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
