Question about Kitchen Ranges
We have a New World built-in fan oven. It had been off for 20mins when there was a bang/pop noise and all our power went out. Turned it back on at the fusebox but the bottom oven doesn't work at all. No light, no fan, no heat. The top oven/grill works perfectly as well as the time display. It's not that old, just out of warranty I think!
  • 2,237 Answers
Something shorted out at the bottom- crossed wires, liquid, mice, etc. check for electrical burning smell. if there is a panel under the oven door, remove it and look for large scorch marks on any wires or circuitry. you might have to take the oven out and look behind it.
Posted on Jul 31, 2009
Whirlpool built-in electric single oven makes a whining noise after it is turned off?
Most of them are equipped with a cooling fan designed to keep the controls from melting... Once it is warmed up, the fan runs until the fan thermostat cools enough to power it off... Cooling Fan W10127321
Jun 29, 2016 | Whirlpool Ovens
Microwave does not warm up food after big bang
oh ya man the heating coil is damaged so you have to change it.
Dec 13, 2007 | Whirlpool MH1150XMQ Microwave Oven
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Inner glass on oven door keeps exploding
i dont think its just yours, ours has exploded in the last 20mins. I cleaned it 2 days ago with mr muscle and put it back together properly.
after googling new world oven smashing loads of people seem to have the same problem too.
Good luck
Feb 21, 2010 | Ovens
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
My hotpoint bs32 oven went bang when I turned it on aftewr a while. I replaced the fuse and the grill and all the functions light up and work except the oven. The fan is working but the oven is not warming...
The fan oven element has failed, you need to replace it with a new element.
You need to remove the inner rear cover of the oven.
There you will see the element..
Unscrew and disconnect the leads and refit new element, be care ful not to lose the wires behind the element aperature.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Ovens
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
