Question about Lexmark X5470 All-In-One InkJet Printer
Paper not feeding correctly
Same problem. When I try to print or copy the paper feeds halfway and then it starts to bunch up and then it stops. It then says load paper and press the checkmark. My printer is about a year old but I dont use it often. I tried to clean my rollers the best that I could but I could hardly reach.After I did that the paper feed through a couple of times then it stop again.
  • 108 Answers
Try to clean the carriage and see if a Q-TIP will reach the feed rollers. They probably still have some ink still on them.
Posted on Jul 31, 2009
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Fax on Lexmark 901 pro not feeding
Does it also jam when you're just copying or scanning? Try to check if the scanner is closed all the way down. The cover needs to be closed all the way down for the paper to flow properly from the ADF to the exit tray.
Oct 27, 2012 | Lexmark Pinnacle Pro901
All lights flashing
Hi
Check through the paper paths for any obstructions.
Remove stuck papers and make sure the paper feed tray is not filled to capacity.
Clear any print queues.
Disconnect the printer from power and re-connect again.
Turn it on and try printing now.
Hope it helps.Thanks!
Mar 02, 2012 | HP OfficeJet 6210 All-In-One InkJet...
I am using Premium Kodak Photo Paper and selecting photo paper in the preferences which I have used successfully before, but have just started having trouble. It started by printing a dark band more than...
Hello. By the sound of it the paper is slowing down at the point were the dark band is. If you can pay close attention to the speed of the paper the entire print. If is appears to slow down, then feeds out correctly, there are two things to look for. The Paper could be sticking in the tray at that point or the rollers are loosing grip. It can also be a combination of both. Make sure no ink or dust has built up in the rollers and also make sure you dont overload the paper feed tray. This increases the bend of the paper through the rollers and can cause them to slip.
Other than this the rollers can be re-set or replaced but it is normally not economical to do so.
I hope this helps Regards GM
Apr 12, 2011 | HP DeskJet 952c InkJet Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer does not fully pull paper...
You probably need to clean the rollers that feed the paper. Check your manual or go to Cannon web site.
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Feeder
Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
Oct 11, 2007 | Brother MFC-8220 Fax
Lexmark X5470 All-In-One InkJet Printer Logo
202 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
