Question about Acer AL1711 17" LCD Monitor
Acer 1711 No Video
When turned on I get green light which supposedly means power and signal are present. However there is no video what-so-ever. The menus do work though.
  • ibuckle Jul 27, 2008
    Yes I have the same problem. If I switch it off then on,, the video displays for about 1s before fading again. I've tried it on several computers to make sure it wasn't the driver.
REF : NO SIGNAL A/V AND TV
Problem developed when switched on in the morning, and noticed above problem.
Tried Auto search on TV and still couldn't tune to any station or work in CCTV mode.
Posted on Jun 22, 2008
I have an ACER AL1916 monitor. The screen is black and the power light is green and blinking. What does this mean?
not necessarily, its just not receiving signal from the computer check your video card that might be the culprit
Jun 26, 2014 | Acer AL1916W 19" LCD Monitor
Monitor was in safe mode turned computor off and removed and replace ram. Monitor now flashing RV370 P N 113 A62801 106 BIOS not sure what to do now. to get computor booted back up
Hi...sounds like your video card has died on you. Do you have another video card lying around to swap out with the old and try?
When the video card is sending power to the monitor, the light will be green - if the light never turns from amber to green when the computer is booting, this means that the video card is not sending a signal to the monitor, probably because its toast.
May 01, 2011 | Computers & Internet
The monitor itself is black, and the power light is changing color from green to yellow to orange and flickering.
Hi there!
Changing the monitor light from green to yellow/orange/amber means that the monitor is in power saving mode. Make sure that the video signal cable is properly connected to the back of the monitor as well as to the computer.
Hope this helps.
Apr 23, 2011 | Acer H233H bmid Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
May 03, 2010 | Westinghouse L2046NV Monitor
WILL NOT LIGHT UP-COMPLETELY DEAD
Hope this helps! :)
May 03, 2010 | E-Machines eMachines Monitor E15T4
The power bar orange light is on but the console won't turn on
The power bar light is supposed to be green, not orange. If it's orange than that means the power supply has gone bad. SOrry :(
Jan 31, 2010 | Microsoft Xbox 360 Console
No Signal error on screen. All connections
Do you see a green power light with connected and power on with computer connected ?
If so, remove the connection at the computer video card, you should see a no signal message.
If you do not have a power on lamp, either amber or green, you do not have A/C power to the unit.
Sep 02, 2009 | Acer 22" X223w LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
