My moved my Toshiba estudio16s to a new office and got a vonage fax line. I can fax fine, but when I receive faxes the line gets interrupted and it either doesn't come thru or I will receive maybe a page of the fax. Since landlines are expensive I wanted to make sure there wasn't a simple fix? Many thanks
  • ajtitlework Aug 07, 2009
    I CAN receive faxes fine if it comes from another VOIP, they don't work properly if its coming from a landline-any ideas?
    President:
  • 3,085 Answers
There is no fix. ALL fax machines are ANALOG, Vonage., DSL are DIGITAL. You need a regular phone line.
Posted on Jul 31, 2009
  • Leroy Elliott
    Leroy Elliott Jul 31, 2009
  • Leroy Elliott
    Leroy Elliott Aug 07, 2009
    That's correct, your fax machine will not be reliable....trust me on this.
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
Can't receive full faxes
If you are sure the fax machine is fine --
With Vonage - you need high speed internet.. slower interment and DSL can cause problems like this..
If you have high speed internet - call Vonage..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well and close the post.
Thank you – and enjoy your day ;o)
Jul 31, 2009 | Office Equipment & Supplies
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to complete fax transmissions
This turned out to be a Vonage issue. I was able to fax from my landline. I googled vonage and mx700 and found a number of similar issues. I also ended up setting my speed to 9600 and turning off TX error reporting. A quick call to vonage and an updated profile (not sure what they did) resolved the issue.
Jan 16, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Alarm, 5003 error, just set up tonight
You could try a DSL filter, but I don't have much faith in them. Vonage is DIGITAL, fax machines are ANALOG and require a POTS (Plain Old Telephone System) phone line.
Sep 11, 2008 | Canon FAX-JX200
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Vonage and faxes
Only real solution I know would be to get rid of Vonage. All experiences with Vonage has left a bad taste in my mouth. Regardless of your broadband speed, Vonage uses open internet and is subject to network problems. Fax's require Real-Time communication/transmission control, which is, thus far, not available with Vonage.
Dec 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
75 people viewed this question
jasbo
jasbo
