Question about Maytag MSD2732GR Side by Side Refrigerator
My Maytag side by side has a water dispenser however the water trickles out what is wrong?
    Scholar:
  • 117 Answers
The problem more than likely is with the water valve.Side/sides have a double water valve with one inlet and two supply outs .The water dispenser valve is probably clogged with debris.Turn off water to valve, remove and clean. If this does not help then valve is probably faulty. Hope this helps
Posted on Jul 31, 2009
Maytag side by side. auger for dispnseing ice will not stop what is wrong?
Are you able to switch the controls to dispense water? I see three possibilities that could be happening. The cup dispenser switch, the dispenser control board or a relay on the motherboard is stuck closed. MSD2274VEM00 Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | Maytag Refrigerators
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
GE Refrigerator Water dispenser trickles
Side like a water supply issue or a kinked line. Good pressure at first then weak pressure after a short time is a restriction in the water flow.
Aug 17, 2012 | Refrigerators
Water dispenser isnt working. Water is slowed to a trickle and ice maker isn't getting enough water to make cubes. We have checked the line from the wall for clogs and it is clear.
Is there a water filter in the unit and if so, when was the last time you changed it? If there is a water filter and the flow of water to the dispenser and icemaker could be impeded by a filter full of "stuff".
Oct 11, 2011 | Maytag MSD2756GES Side by Side...
Water dispenser is dispensing water at a trickle
The water filter is the first item I would check. I just repaired a s/s with the same problem and it was the water filter.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
Maytag MSD2732GR Side by Side Refrigerator Logo
286 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
