Cars & Trucks Logo
Mike Rall Posted on Mar 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
And my other Memphis amp that I have it was-working fine one day and the next it was blowing the fuses and I put a fuse in any blows it
Justin H. Reed
Level 2:
Sergeant:
  • Cars & Trucks Expert 317 Answers
  • Posted on Mar 25, 2018
Justin H. Reed
Level 2:
Sergeant:
Answers
317
Questions
0
Helped
111184
Points
670
Hi. Thanks for your question. For assistance on issues related to Memphis amp and fuse issues you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 20, 2008
SOURCE: 98 PLYMOUTH GRAND VOYAGER WONT START - BLOWS ENG FUSE - HELP
You have a shorted engine harness, this is not common but it does happen, heat and engine movement cause damage to the harness, this is most common on hi miler cars and vans, the only way to fix it is to start by looking anywhere the harness rubs, that is where the damage occurs.
Ronnie Wilson
  • 1596 Answers
  • Posted on Jan 09, 2009
SOURCE: 2o amp starter fuse blows
This is a iindication of Hi resistance in your starter, thus starter May be on its way out
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jan 31, 2009
SOURCE: 2002 Dodge Neon 20 amp FP/ASD fuse #21 keeps blowing
It appears that it is part of the fuel pump circuit, so I would concentrate on wiring harness & connector at fuel pump, clean it real good, and apply dielectric grease to the connection, as well as the fuel pump relay, connector & harness.
Anonymous
  • 366 Answers
  • Posted on Mar 11, 2009
SOURCE: 2001 S-10, Blowing "ECM Batt" fuse after running for about 30 min
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
Anonymous
  • 6 Answers
  • Posted on Oct 22, 2009
SOURCE: 20 Amp FP/ASD Fuse #21 keeps blowing.
hmm. lt look like there are poor joints in your wiring specially the groung wire. check the diagram of your auto. check the unit diagram for which the fuse blows. usually the fuse blow when there is a short circuit. if you look around you will find it.
good luck
ehsan.
I have a 2008 harley davison heritage softail Blow the ignition fuse. Got it home the next day it ran fine Went to auto parts to git fuse Came back put one in works Started it up 12 or more times...
i9ndicates that you have dead short problem in a component in the ignition system
could be a bad ground causing excessive current ( arcing) when component is moved or wiring moved
maybe an auto bike auto electrician could pinpoint the problem area
possible a voltage control problem causing excessive current through the fuse , intermittently causing it to blow
Again a bad ground in regulator problem
Why does fuse 15 keep blowing on citroen picasso 2007
change the fuse from 15 amp to 20 amp will cure your problem
Number 15 fuse keeps blowing
Possible causes:
- Fuse is under rated.
- Short circuit in wiring.
- Fuse No. 15 is overloaded.
- Positive wire is shorted to ground.
- Check all the loads one by one which are put on this fuse.
I have a 1994 Ford Thunderbird LX V8. A few months ago when I put the car in park, the air conditioner and the battery amp guage quit working. I found a fuse that was bad and I replaced it and then the...
I'm betting it has something to do with the shift lock actuator or the harness to the actuator. I'm pretty sure it is located on the top of the steering column on your vehicle. The lower part of the dash will need to be removed and then the steering column lowered in order to gain access to it.
This vehicle does have an airbag and unless you experience with airbag systems I would not recommend tackling this yourself.
unplug the interlock. Replace the fuse. Start the vehicle. with your foot on the brake manually release the interlock with you hand and shift through the gears. If the fuse does not blow your on the right track. If the fuse does blow let me know and I'll get you some more info.
Let me know if you have any questions and thank you for using Fixya.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Blowing 20 amp fuse
Hi that fuse should be a 25 amp and it runs the blower, heater, the day time running lamps, automatic light control and the rear defogger you would have to check each unit at a time what I would do is put a hire fuse and look for smoke on the wiring as soon as iI see whats burning I take the fuse off but you have to be quick and pull out the fuse before any thing burns if not check each unit mention and look for good luck.
1helpful
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
