Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Cycling on and off
Hi, can you help?
when I turn the player on or try to charge it, it goes into a perpetual cycle - on, off, on, off, etc. I have to take the battery out and replace it to stop it.
I'm desperate!!! creative zen jukebox 60 gig
  • dagalan Dec 06, 2007
    That was the first thing I tried - No Luck! Thanks for thinking though.
  • jskel Dec 06, 2007
    I also have the same problem with cycling on and off. It is driving me crazy.
    Any help would be appreciated much.
Try resetting the device
  • Take a paper clip and open it
  • press it into the reset button on the left side of the unit while ht power is on
Posted on Dec 06, 2007
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Jan 11, 2015 | Zanussi Washing Machines
Hi, my swimp3 was not used for the last 2 months. I charged it up full yesterday and when plugged into the computer it plays well (i.e I can format it, change songs, actually have it "play",...
Hello nehajo88,
Thank you for contacting us. I work in the FINIS Technical Support department and would strongly recommend that you go to our support page and create a ticket so we can process you for a replacement as it seems to be a defective unit. So please visit our support page ( and create a ticket and I will be happy to further process your case there.
Aug 02, 2011 | Finis Swi MP3 Player
Bosch dishwasher model: SGS56E02 will not complete a cycle.
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more...
Sep 27, 2009 | Bosch Dishwashers
My computer has sat for 14 months and now it will not turn on.
HI, this is quite a while for a cpu to sit without a charge or, plug in cycle. If this is a PC desktop, you may need to replace the motherboard battery and, main power supply as well.
Now, if this is a laptop, you will need to replace the battery(external rechargeable cell).
Jul 11, 2009 | Dell Inspiron E1705 Notebook
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
May 20, 2009 | Asko Washing Machines
My sansa mp3 just froze in the welcome screen when you turn it on
Try these steps:
 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 22, 2009 | SanDisk Sansa m240 MP3 Player
Hi, from mexico n800 problem
Are you sure it's the right charger? The charger is not supplying enough "juice" to keep the N800 on when it turns on. Once it turns off, it charges enough to try and turn on again... hence the endless loop of power cycling.
Hope this helps,
Dec 22, 2008 | Nokia N800
M240 sandisk! song cycles!
have you tryed to plug it in and let it charge thats what i did and make sure its not locked on the top
Nov 27, 2008 | SanDisk Sansa m240 MP3 Player
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washer LSQ8543JQO -- in cycle issue
what brand washer? if lidswitch is bad most washers will not drain and spin to move to the next cycle
Nov 19, 2007 | Washing Machines
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
85 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
