Question about Kenmore Sewing Machines
I have an older kenmore sewing machine. I have it threaded and it runs but no stitches are formed
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the thread in the bobbin, it shouldn't be tangled. Remove the cover plate, take out the bobbin by sliding the cover plate to the right. Follow this procedure to fill the bobbin with thread-
  1. Pull the clutch know away from the machine to disengage clutch.
  2. Draw the thread from the spool.
  3. Guide the thread around the bobbin winder thread guide.
  4. Insert the thread through the hole in the bobbin, threading from the inside to the outside.
  5. Put the bobbin on the bobbin winding spindle, and push it to the right.
  6. With the free end of the thread hold in your hand and depress the foot control (if using).
  7. Stop the machine when it has made a few turns and cut the thread close to the hole in the bobbin.
  8. Return the bobbin winder to its original position by moving the spindle to the left and cut the thread.
  9. Push in the clutch knob to engage clutch.
Also see this link for the Use & Care guide for your Kenmore Sewing machine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2009
Normal tension for kenmore model 158.12112?
Remove the thread from your machine. Install a brand new needle.
Rethread the machine from the beginning being sure to ALWAYS RAISE the presser foot when threading the upper thread. Make sure the thread path is correct and that the bobbin is loaded and threaded correctly. Set the upper tension to the midway point--the factory standard, but every machine will probably require some tweaking.
If, after testing your machine, stitches are still not being formed, it is quite possible the machine is out of time. Search for sewing machine timing or take it for service.
Mar 21, 2017 | Kenmore Sewing Machines
I have an older Bernina 830. I am having what seem to be tention broblems with the stiches not forming and lots of thread being produced. The adjoining problem is that there is a rattling when I attem
What you're describing is commonly called a 'bird's nest' for fairly obvious reasons. There are, unfortunately, a number of things that can cause it.
Troubleshooting steps:
1. Clean it! I've seen machines that haven't been properly cleaned for years. If there is lint, dust or dirt in the bobbin area especially, the looper won't work correctly and the stitch won't form. Be sure to take out the bobbin when you do this.
2. Oil it. Follow your manufacturer's instructions for this. If you don't have a book, contact Bernina and get one.
3. Change the needle and check the tensioning disks to be sure that no lint, old thread, etc. has got caught in it.
4. Adjust the tension. This can be tricky, so take it in small increments. Here, again, a manufacturer's book is a godsend.
5. If none of this avails, or it only partially fixes the problem, take it to a reputable service center (most fabric, quilting, etc. stores have or know someone) and have them adjust the timing. Most machines need this done every 1-5 years depending upon the usage.
Good luck with it. I wish I had an older Bernina, they're good machines.
Feb 14, 2015 | Bernina Sewing Machines
Kenmore 158 17310
Tension is wrong. Set tension in centre position for optimum results. Try resetting bobbin and tension on the machine front. Also, make sure your threading is correct. Thread can also cause problems. Try a different gauge of thread as well. Also, the fabric may be too fine for the tension. Place a piece of tracing paper under fabric to make it more stable. Also check that your foot is down (lever control).
Jul 28, 2014 | Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Sewing Machines Logo
60 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
