Question about Poulan "Poulan" Push Mower
Starts then dies unless you keep pushing the red bulb
22" push mower will not keep running
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
You will have to remove the fuel bowl from bottom of carburetor and clean the varnish out of the carburetor.Take note that the screw on the bottom of the carburetor is a fuel metering jet,there are small passages in it that may need to be cleaned out with a small wire,be careful not to enlarge the holes in it,they are important for fuel metering correctly.You may have to soak it in carb cleaner. Be sure to use good carb cleaner. The brand name Berkebile 2+2 is the best followed by Gumout.
Posted on Jul 31, 2009
Primer bulb collapsed
Slightly unscrew the gas cap and see it the problem goes away.
Many times the Gas tank Vent clogs and this will cause the engine to create a vacuum in the gas tank until the engine can't draw in the gas .
Jul 15, 2013 | Garden
Lawn boy 10685 starts but will not run
clean the carb there is dirt in the jets
May 03, 2012 | Garden
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
May 05, 2010 | Mtd 22" Yard Machine Push Mower
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
Have B&S 4hp lawn mower (20") Engine keeps dying after short bursts. I think it's the governor that keeps going back and forth and killing motor. HELP!
If its the 4hp classic type Briggs engine with the red primer bulb on the side of the carb then it needs a new diaphragm. Very cheap and simple repair.
see this link for a good picture + price
http://shop.jungle-busters.co.uk/epages/es122164.sf/en_GB/?ObjectPath=/Shops/es122164/Products/795083
Oct 05, 2009 | Mtd 22" Yard Machine Push Mower
Will not run
If you mean you are pushing the primer bulb when you say press the choke and gas comes out from around it, your primer bulb has either cracked or come loose. If it only has 3 hours on it, it should be covered under warranty unless it is too inconvenient to take it back to the dealer or an authorized repair shop in which case you will have to determine whether it is loose or cracked and replace or repair it.
Sep 22, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Sep 19, 2009 | Garden
Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Apr 05, 2009 | Mtd 22" Yard Machine Push Mower
Poulan "Poulan" Push Mower Logo
437 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
