Question about LG Ovens
Lg oven f11 code
Waiting for oven to heat to set temperature. Makes it to 100 degrees to 150. Then oven beeps and there is a f11 code on control board.
    Master:
  • 851 Answers
You need a qualified repair facility to check it out. the thermistor could be defective, or the control board.
Posted on Mar 25, 2018
SOURCE:
MNTECH
  • 1543 Answers
SOURCE: Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Posted on Jan 08, 2009
  • 1300 Answers
SOURCE: oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
Posted on May 09, 2009
  • 57 Answers
SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Posted on Jun 27, 2009
  • 4 Answers
SOURCE: ovens wont heat to temp
What model oven or ovens? Is it a double stack or single? If double does it happen to both or just one?
Posted on Sep 12, 2009
barkencoa
  • 3463 Answers
SOURCE: my oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Posted on Dec 15, 2009
Testimonial: "Thanks, I will definitely check pricing and installation costs for this part."
F11 error code
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
Aug 13, 2014 | Frigidaire FGB24S5A Gas Single Oven
How do I clear a f 11 fridgedaire oven
Good Afternoon Friend, this is Z. I appreciate your post!
Jul 31, 2014 | Frigidaire Ovens
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
How do you reset the frigidaire wall oven?
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Ovens Logo
3,029 people viewed this question
Top LG Ovens Experts
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
pawnpower
Are you a LG Oven Expert? Answer questions, earn points and help others
