Question about Microsoft Windows XP Home Edition with Service Pack 2b for PC
How do i enable usb in bios i can't seem to see the option in the bios screens i am assuming they are not enabled as my computer doesn't recognise any usb devices after i performed a complete system reinstall HELP!
You need to have your device plugged into computer first. After that when you attempt to boot up if you can get to the BIOS screen you have to change the order in which the computer loads data, instead of having the comptuer load from the hard drive it will find the file on your usb device when you switch the order of command. When you exit the screen the system will attempt to boot from that device that one time, any other attempts have to be re-setup. Hope this helps!
Posted on Jul 31, 2009
Sony vaio pcg9s1l
Enter the BIOS screen and go to Boot Order; if booting from USB port option is not enabled, then enable it. If there is no USB boot option you cannot boot from a USB drive on that computer.
May 14, 2014 | Computers & Internet
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
My 3660 does not recognise my DVD/CD write/rewrite theough the connections are all fine. Same too with my new Sony Walkman when plugged into any of my USB drives
Do any devices work in any USB ports on that laptop (Flash drive, mouse/wireless mouse, USB keyboard)?
USB support may be disabled in the BIOS.
Boot into the BIOS and check the built-ins and enable, if necessary.
(just in case, disable and then enable)
USB controller driver messed up:
Right-click [My Computer]
[Manage]
[Device Manager]
Look for any "marked" errors on devices
open the +USB Serial Bus Controllers
Pick a faulty one and "disable" then "enable" it.
If it still fails, then "Uninstall" it (Windows will find it and re-install it automatically.
That should do it.
Sep 22, 2009 | Acer Computers & Internet
How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get to if you press F12 during start up, before the Windows screen appears.)
  1. Go to "Enter Setup"
  2. Go to "Config", click "Enter"
  3. Go down to "USB", click "Enter"
  4. Make sure that "USB Bios Support" is enabled.
  5. (Hit "Enter" again and choose between "enabled" and "disabled")
  6. Hit "Esc" twice to go back to the main page.
  7. Go down to "Startup", click "Enter"
  8. Choose "Boot"
  9. Check if "USB CD" is in the list of boot options or excluded form booting.
  10. Hit F10, confirm any changes you made (click "Enter" for 'yes') and reboot.
  11. Tap or hold down F12 again and you should see the boot option menu again.
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is possible that the T22 BIOS does not support external booting. Check you version - the latest release from IBM is version 16ET32WW (1.12), release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
Jan 30, 2009 | IBM ThinkPad T22 2647 Notebook
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
HP Pavilion zv6000
Hi there'
if you would please try this power down the computer and reboot and press the del key as it starts up this should bring you into the bios screen now go down and ensure that the plug and play is enabled now go to the perephial section and look for the usb and make sue that it is enabled save and exit and reboot once you reboot see if the computer recognises the usb devices you are installing best regards mike
Aug 08, 2008 | HP Pavilion (PN153AAR) PC Desktop
Microsoft Windows XP Home Edition with Service Pack 2b for PC Logo
362 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
