Question about Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame
Pictures don't fill screen on Kodak M820 Digital picture frame
I've had this frame for 7 months and everything was fine until I upgraded to Kodak's new version of software. Now none of my pictures will fill the screen. I've checked the settings and they are fine. I've upgraded the firmware too. I've emailed Kodak 3 times and they are no help.
    Scholar:
  • 47 Answers
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Posted on Jan 04, 2010
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
I have put a micro card in a kodak easyshare unable to retrieve
Ok, look for a stick of broom or any other thing that is as tiny as a broom, insert it into the card slot and look for a way to bring the card out with it.
Or maybe you should loose the cover of the easyshare m820/m1020 so that it would be easy for you to access the internal part and it would me more easier for you to remove the card.
Take care.
Dec 28, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
The kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 14, 2009 | Kodak EasyShare EX1011 Digital Picture...
Can not add pictures to Kodak
To get a good start, you reformat the frame's internal memory by following the steps below: 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. Forget about using any software. Once you connected your frame onto your Macintosh, it will appear as a white drive icon on the desktop. You can copy pictures “drag and drop” from iPhoto to the frame. Just make sure that the pictures you will be copying are in JPEG or EXIF format.
Feb 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
My kodak ev1011 pic frame stopped working
You may try the online troubleshooting guide at www.kodak.com/go/itg and if it does not resolve the issue at the end of the guide you can fill out a form to send the frame for repair and also just an FYI the frame is warranty for one year and you must a copy of your receipt before sending the frame.
Jan 08, 2009 | Kodak EasyShare EX1011 Digital Picture...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
328 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
