SOURCE: Moldy smell in front load kenmore washer
What you all are forgetting and I can vogue for this and prove it because we ripped our washer down......and I have pics... the mold will collect behind the SS tub in the plastic drum housing... every repair man told me NO POSSIBLE WAY!!!! well I was so sick of being sick and my husband decided time to buy a new washer we did and a (top loader i will add). and when the top loader was delivered we ripped the front loader totally apart (any one that would like to see pics you can email it) but be forewarned they are GROSS!!! I have done all the maintenance they have recommended and nothing helped (bleach, cascade, OXY, vinegar, leaving door open (which i may remind anyone is a risk if you have toddlers ) oh yes and lets not forget the washer magic they push down your throat to buy every time a sears tech comes out) I have a family of 6....4 girls and 2 of them babies so I have a lot of laundry....I will be more then happy to share what we found was hiding in the washer's this is not something you can see until you rip it totally down. CJ
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: He2 plus front load washer
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Hello & Welcome to FixYa
ND error in your Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
ND error in your Samsung Front Load washer
the pump. Please get back to me if you have any other questions.
Kevin
