My washer is 8 to 10 years old its a kenmore 29042 it trys to wash it seens to cycle but when its time to spin it does not. the timer makes a ticking noies what could it be cheked the belt it seem fine I can turn the tub with the belt motor makes the washer go back and forth but will not spin or turn at all during rinse or spin thanks kay
  • duanekaybo Jul 31, 2009
    kenmore 417.29042991
    would it not turn at all if it was the motor cause the tub moves back and forth while washing cycle just will not spin
  • Washing Mach... Master
  • 19,396 Answers
If the timer board is making ticking noise and the machine is not spinning, you can have a faulty timer control, or a faulty motor.
I can be more specific if you give me the model number as printed on the service tab.
Posted on Jul 31, 2009
  • Ginko
    Ginko Jul 31, 2009
    If it only does not spin it can still be the variable speed motor.
    Apart that it can be a number of things.
    Please give me the model number so that I can refer to specific parts, things are different if there is an MCU or not.
    By the way , if the board is clicking, the first thing to do is having a look at the timer board and test it.
My Kenmore 11020022012 washer stops prior to spinning cycle. If I manually turn the dial to spin, it will spin fine. Need help troubleshooting..
timer needs new electric motor to advance from rinse to spin cycle.
or alternately ,you can have your old timer taken out of your washer and sent out to be rebuilt or buy a new timer.
in any case , you will need a kenmore washing machine repairman to take out your old timer and send it away to be rebuilt and expect that to take 2 or 3 weeks
the timer rebuild used to cost$ 50.00 in 1993 and a new timer went for $110.00 to $129.00
for a sevice man to take out and reinstall a timer $60.00 to 100.00 labor
try to google.com or bing.com or ask.com-----and type in : kenmore washing machine,rebuilt timer. you will need the model number of the washer as well as the model number of the timer and the timer may have a different name that kenmore
also try typing in kenmore washer,new replacement timer
try call sears and see how much their service man wants to put in a new timer. I am sure prices have gone up since 1993
when I retired from the major appliance repair busness. i could do the timer remove & install, but I probably live 1000 miles from you.
another option: knowing that you will need to spend around $200.00 or more by the time you get a new timer installed
you might want to see how much lowes or home depot wants for their cheapest bottom of the line washer. that might be a good alternative as it allows you to get a new washer and buy an extended warantee so you dont get stuck with another 200.00 repair. I think they have washers starting at 289.95 only 90.00 morte that repairing your old washer which is going to run for how many more years before it again gives you trouble?
check out lowest prices on bottom of the line washers unelse you want to spend a lot on a fancy washer to make yourself happy.
you can shop on line by just google.com or bing.com and the name of the store. home depot, lowes, sears,walmart
and type in clothes washers.
Oct 08, 2013 | Kenmore Washing Machines
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
I am washing clothes in a borrowed Kenmore washer. It's probably 10 years old. It stops short of completing the Rinse cycle and never makes it to the Spin cycle. The bowl will start filling up w/ water,...
This is a typical problem with the "lid switch" on the washer. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore Washing Machines
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
My kenmore washer Agitates but doesn't spin/drain
your help has arrived!
buy new timer! and install exactly the way you took out with the wires
Jun 10, 2009 | Washing Machines
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Maytag commercial washer gets to spin cycle and stops
It sounds like your timer is defective
FIX
When the machine gets to the rinse cycle slowly advance the setting to manually advance the timer
if it just sits bang on the panel or around the knob and listen if ou hear the timer start ticking you will need to replace it
Timers are avaliable from appliance parts suppliers around $29 you can get someone to install it or if you are handy can do it yourself
good luck
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 12502 won't spin
The lid switch is broken......
Oct 05, 2007 | Kenmore 12502 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
