Question about Fellowes Office Equipment & Supplies
DM17Cs turns on for just a second then clicks off
    President:
  • 3,085 Answers
Pulse timing wheel is dirty. Blow out with canned air. It's a small black disc with slots in it.
Posted on Jul 31, 2009
How to repair flellowes shredder
Without further information as to the exact issue you are having, here is a like to YOUTUBE with various videos on shredder repairs.
http://www.youtube.com/results?search_query=fellowes+shredder+repair
Jul 10, 2014 | Fellowes DM17CS Confetti-Cut Shredder
Where can I buy replacement nylon fellowes gears
Have you tried http://www.hpcgears.com/? They're a good company to deal with and stock a huge range of gears for many machines.
May 10, 2014 | Fellowes DM17CS Confetti-Cut Shredder
Jeep cherokee when in drive, front right under the hood clicks and the RPM's kick for about 2 seconds this cycles about every ten seconds.
its hard to say is your ac compressor kicking on i need more details on where the clicking is coming from ac compressor is a guess due to it raising rpms when turned on and makes clicking noise turning on and off
Dec 05, 2012 | Cars & Trucks
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Turns on hear a click shuts off
Bad thermostat is the most lilky cause,
Jun 20, 2010 | Haier Water Dispenser w Fridge...
I have a second hand linksys router, but dont have the software or CD to install it, how do perform the connection to my PC? thank so much for kind help
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Connect the wire (which is coming out from the modem) to the WAN/Internet port of the router.
2.Connect the computer to either of the four LAN ports of the router.
3.Turn on the router and press and hold the RESET button for 30 seconds. Turn off the router and turn it on after waiting for 30 seconds.
4.Type 192.168.1.1 in the address bar of Internet Explorer and hit enter.
5.Leave the username blank and type admin in password.
6.In the setup page make sure Internet Connection type is set to"Automatic Configuration"
7.Click MAC address clone and select Enable and then click the tab CLONE. After that click Save Settings.
8.Now click Wireless(to configure wireless) and fill the sections as mentioned
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
9.Click Wireless Security and fill the sections as mentoned
Security Mode-WEP
Default Key-1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
10.Since it is a second hand router, I would suggest you to please upgrade the firmware
Please follow the link: http://homesupport.cisco.com/en-us/wireless/linksys/
Enter the model number and click the Download tab. Then enter the version number(which you will get once u turn upside down the router) and download the firmware and save it on desktop.
11.On the router setup page click Administration and then click Upgrade Firmware.
From here upgrade firmare and turn off the router for 30 seconds. Turn it on and enjoy.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 13, 2010 | Linksys Wireless-G WRT54G Router
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
74 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
