Question about Epson Stylus Photo R300 InkJet Printer
The printer tells me all the ink cartridges are empty and refuses to print. All the cartridges have ink and are inserted properly Tells me 2 cartridges are empty; after replacing those, it still says empty.  Next I replaced each and every one with new Epson ink cartridge with same results.  I cannot get to place where I might check to see if clogging is a problem because it just keeps telling me those cartridges are empty. Thanks,Jo-Ann
  • 709 Answers
Hi Blackburn,
Get you some rubbing alcohol and Q-tips. Disconnect the power from the printer and remove the Ink Cartridges. Using the q-tips and soak them with the alcohol. Clean the electrical connections in each of the cartridge ports. You might go through several Q-tips before geting them cleaned up good. If necessary use Finger nail polish remover instead of Alcohol to get any contaminants off of the connections. Test a site with the fingernail polish remover first before dabbing it all over. I am afraid that it may eat up the electrical connections.
Posted on Nov 24, 2007
My printer is EPSON STYLUS T10, it does not work but their's a confirmation that my ink is no more, but since there is,, answer me please, how i must repair...
This is a major problem with epson printers. Each ink cartridge has a chip which estimates the amount of ink remaining. In my experience this is always WRONG, it always tells the printer that there is less ink than there actually is. Along with this, if any one of the cartridges registers as empty, then the printer will refuse to print. If you use remanufactured or refilled cartridges then you will probably get these problems. You have no option but to replace the cartridges even though you know there is ink in them.
Feb 23, 2011 | Office Equipment & Supplies
Refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
Feb 25, 2010 | Lexmark X9350 All-In-One InkJet Printer
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
My 2-year old all-in-one now refuses to print anything. It tells me to replace empty cartridge(s), without, as previously, indicating which one(s). I have tried replacing them all, but still cannot print....
I understood once that keeping the reset start reset button pressed for a few seconds might reset it ..and will not see the cartridges like empty ones anymore
Nov 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brothe printer MFC5840CN
yes..that's not unusual...sometimes you need to run a recalibration and cleaning for the new print cartridges to interface with the computer software..
Apr 21, 2008 | Computers & Internet
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Are the cartridges refurbished, or refilled, or compatibles? If so it is possible that they are being misread by the printer or that they have not had the chip reset.
If they are genuine Epson carts and are all new then the issue mist likely lies withe the printer. Not a problem you can easily fix yourself. I would suggest you take it to an Epson dealer to be checked out. It may need a main board.
Nov 20, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
