Question about Coleman Powermate Premium Plus 6250W Portable Generator
No power output.Put in new brushes and cleaned 6250
No power output.Put in new brushes and cleaned contact surface but still nothing
  • 90 Answers
Check the capacitor
Posted on Aug 02, 2009
How uch oil should go intoa new 6250
maybe you should say what is a powermate 6250??? im going to assume a genset but im not sure about it.
Sep 10, 2017 | Electrical Supplies
I've got a coleman 6250 that runs great! Motor wise that is. There's apparently no electricity coming out, and the brushes are new. I'm at a loss...any suggestions?
Shut it off, restart. May have condensation. This happened to me with a generac. OH! OH! OH! Check your fuses! Generator will start, but produce nothing MAY just be a fuse.
Oct 02, 2016 | Coleman Electrical Supplies
Generac 5500XL, model#09778-7 no output. Changed the power regulator board. No luck. Flashed the 120 plug with 12-30vdc from DC board. Nothing. Excited the brushes directly with DC board. Only got 2.36VDC...
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Jan 22, 2010 | Coleman Powermate 5000W Home Backup...
Just replaced the brushes on a WE14 150 Quick 6 Grinder and sparks now come from the brushes
From my own experience.
Are the strips of the commutator smooth and flat?
(Not to insult you. The part of the armature that the brushes ride on)
If they aren't, the brushes will bounce up and down.
I put one end of the armature in a drill, and have a helper run the drill. The other end of the armature rests in the front bearing of the grinder head, which is fastened down. (To a bench) Then I use a medium tooth, (B astard) file to dress the commutator bars flat.
I also put medium grade sandpaper in-between the brushes, and the commutator surface to dress an arc on the brushes. (Turn the armature by hand while keeping the sandpaper in place)
Brushes come with a flat surface. Putting a radius on them to fit the arc of the commutator, gives them a good contact surface to start from.
Be sure the springs are putting pressure on the brushes. Sometimes the brush mounts need to be cleaned, or the brush will not slide through the mount like it should. The brush will again, 'Dance' on the commutator. (Bounce up and down)
Sep 06, 2009 | Metabo WE14-150 Quick Angle Grinder
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
Aug 16, 2009 | Coleman Powermate Premium Plus 6250W...
My Coleman Powermate 6250 generator has no power output. After the carburator was cleaned, I flashed it. A voltage meter shows there is power being generated, but none so to light a light bulb. What to do...
Take the cover off and flash the rotor again with a 12 volt battery. Positive lead goes to the top or right side brush. Negative to the other brush. Just touch it on, then remove it, and check for power at plugs.
If that doesn't do it, change the AVR (voltage regulator)
Aug 05, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate 6250 model pm0545007.01 engine runs no a.c. output
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
368 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
