Question about Whirlpool GHW9200L Front Load Washer
Rear shocks whirlpool duet GHW9200LQ front loading washer
How do I remove the shocks on this washer? I need to replace the left rear shock if you are facing the machine. I cannot figure out how the tabs work, its driving me nuts.Please help........
    Champion:
  • 249 Answers
Press tabs inwards, at the time TAP the pegs holding the shocks in place.Get the hen to give you a hand .close IRE bye bye
Posted on Nov 24, 2007
  • 447 Answers
Ok its hard to remove the shocks without breaking the little tabs. You can tell which way they rotate out right?? There is a stop tab that stops the shock when its locked in. Rotate the other way, I use pump pliers (crescent wrench) and gently apply pressure until the tabs give. The new shock has new tabs and all..
Frequent out of balance problem
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Aug 18, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer not level
unit has four feet, to level, however, the "shock absorbers" with in the unti may have come undone, try removing the lower acess panel( 3 torx 20 screws) across the bottom front of unit, youl be able to see inside and posibly locate the broken shock(s)
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer rattles and knocks when spinning
you either have a broken shock or the spider gear is gone,take off the bottom panel and check out the shocks,if it's the spider gear it's time for new washer,it's around 500 bucks for new gear,to much detergent used over the years eats at the metal
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washe always out of balance
remove lower front panel and you should see shocks on lh/rh of tub. probably one broken ,replace both. Hope this helps, please rate my solution :)
Jun 25, 2009 | Whirlpool GHW9150 Duet Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
452 people viewed this question
Dan Webster
Dan Webster
Sal De
