Question about Philips 42PF7220A 42 in. Plasma Television
Ii own a minteck lcd dvd combo
I own a minteck 37 inch lcd dvd combo I purchased the shrek 3 tape and it says it is loading but ten it says to upconvert to 1080i i did and it still will not play I have hdtv is there something I am doing wrong or is there something else i need to do please help I thought it was the tape but I returned it and got another one and still will not work
View Details Product MPN MPN DTV-373-D Key Features Flat Panel Type LCD Television LCD Response Time 8 ms Screen Size 37 inch Contrast Ratio 800:1 Digital TV Standard HDTV Television Display Resolution 1366 x 768 pixels Display Capabilities Digital TV Standard HDTV - HDTV receiver is integrated. Broadcast Format Displayed 720p (HDTV) • 480p (EDTV) • 480i (SDTV) Broadcast Format Supported 1080i (HDTV) • 720p (HDTV) • 480p (EDTV) • 480i (SDTV) Built-in Tuner ATSC • NTSC Native Aspect Ratio 16:9 Image Quality Display Resolution 1366 x 768 pixels Brightness 500 cd/m? Viewing Angle 176 Connectors Rear Input Connectors S-Video x 1 • S-Video x 2 • Component x 1 • Composite x 1 • Composite x 2 • HDMI x 1 • HDMI x 2 • Audio (RCA) x 1 • Audio (RCA) x 2 • 1 x RS-232C Miscellaneous Product ID 37709064 More Information Mintek DTV373D high definition 37 Inch LCD television is slim, lightweight and designed to suit any room in your home. Each Mintek LCD TV is incorporated with a DVD player, HDTV ready, PC compatible and Memory Card and USB sockets for digital photo viewing creating a sensational multi-media system
I have a Mintek lcd/dvd combo which when turned on , comes on with picture and sound but the picture goes off in about one second. I removed the back and can see that the back lighting is going off. I measured some voltages at a terminal strip that i believe provider the back lighting for the set. The results seemed to be normal to me. Can you suggest where I should look further.
Posted on Jan 18, 2008
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ... > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Cant get the dvd to work cant put a disk in it a proscan tv dvd combo
Disc loading mechanism fault. Contact any service technician to replace it. This is not a user repairable fault.
Jul 13, 2015 | Proscan 37 in. Diagonal Class LCD...
I want to buy a AV cables for a initial 37 inch dtv-372 (db-4500
AV cable can be bought from most of the electronic spare part selleing shops at your town. It will look like this.
Nov 14, 2011 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
I need a power cord for a polaroid HD TV 81.5 INCH
Try using the power cord from your PC. NEMA5-15P to IEC C13.
Jul 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
What channel do you watch a vcr/dvd on.
It depends on the way you have the combo set up, your instruction manual shows you different ways of doing this, but to answer the question it would be channel 3 or 4 if you are using the RF out ot OUT to TV connector in the back of your combo. You can also view tape and disc playback if you set the TV for VID1 or VID2 if you are using the rca dubbing cables(yellow-red-white).I hope this helps!
Jan 05, 2010 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
32 inch tv/dvd combo cuts off on its own
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.//
Feb 05, 2018 | Akai LCT3701AD 37 in. LCD Television
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Sep 09, 2008 | Televison & Video
Go Video DVD/VCR Combo Unit Model VR3840
try to play videos from over seas Taiwan, but when I set the settings it will not play
Nov 27, 2007 | GoVideo Go Video DVD/VCR Combo
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
