Question about Electrical Supplies
Does old Lightolier cause lights to blink. Not
Does old Lightolier cause lights to blink. Not completely on and off
  • 152 Answers
I assume lightolier track lights? loose wire or loose connection either in ceiling or at switch... if they are all blinking then it is most likely the switch.
Posted on Dec 06, 2009
Lightolier 3 way remote wiring
If you have determined the wiring to be correct, then yes, the remote is probably defective..
According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
I hope this helps & good luck!
Jun 01, 2012 | Philips Lightolier Onset 600W Incandescent...
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
I can't get the yellow wire of the dimmer slider to work properly using a conventional 3way switch on the other side. I do have the slider on the load box. Could it be that i need a Lightolier ZPR-3 on the...
Most of this style lightolier product requires the proper remote such as the zpr3. Leviton illumitech is a similar design, but uses regular 3 way wiring.
There are others out there as well, that do not require the remote.
Mar 05, 2011 | Lightolier 600Watt Preset Slide Dimmer
I would like to replace my lightolier zp600 dimmer to a zpr-3 that has the same wire wiring diagram as a zp600
The zp600 is the master, and the zpr-3 is the remote. With only one location you need to use the zp600. For multiple locations, you use the zp600 at the load side and zpr3's at other locations with all the yellows hooked together, and all the blacks hooked together except the black going right to the light. This hooks to the red at the zp600
Feb 15, 2011 | Lightolier Sunrise Preset Incandescent...
My F4280 has blinking on light and blinking cartridge lights and the letter "E" in the Start Copy window, cannot scan or make copies but printer part works. Message in desktop says "Scanner Failure" but...
The product uses various combinations of flashing lights to indicate its current status.
  1. Turn off the product.
  2. Disconnect the power cord from the electrical outlet.
  3. Wait 60 seconds.
  4. Reconnect the power cord to the electrical outlet.
  5. Turn on the product
Issue
The Check cartridge light is blinking. Cause one
The cartridge door is open.
Solution one
Make sure that the cartridge door has been completely closed. Cause two
The cartridge is missing or not seated correctly.
Solution two
Insert the cartridge by sliding it forward into the slot correctly. Cause three
The tape was not removed from the cartridge.
Solution three
Make sure that the plastic tape has been removed before inserting the cartridge into its slot. Cause four
The cartridge is not intended for use in this product.
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Aug 06, 2010 | Office Equipment & Supplies
Eaton afci breakers tripping out due to lightolier low voltage lighting. Lightolier and eaton both agree that it is a frequency problem but neither has a solution. Any help?
everytime I plug in my vacuum cleaner (Kenmore canister model) I trip the Eaton AFCI Braf breaker. Now it doesn't even work though I can flip the switch back to the on position
Jul 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Ballast / dimmer compatability
i believe thats a magnetic ballast couldn't find it on the net... but anyway use a magnetic type dimmer for a magnetic ballast and an electronic flourescent ballast dimmer for the same..
Jul 01, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
End of Run Dimmer Switch Installation
take a look at the old switch that you have taken out, just connected the new one as the old. with the ground to the switch box.
Since the new one is not marked, you can connect the black on either side of the switch.
May 28, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
Flashing lights instead of shutting off
14 years does seem like a reasonable life span for a dimmer. My suggestion is to turn the circuit off, take the dimmer out, wire nut the two wires together, turn the circuit on. If the light comes on normally get yourself a new dimmer ($10). Make sure to turn the circuit back off before installing the new dimmer.
Jan 15, 2009 | Lightolier Sunrise Preset Incandescent...
Electrical Supplies Logo
217 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
