Can i connect my pc to the tv - Televison & Video
  • 2,237 Answers
Only if you have a vga input on the tv.
Posted on Jul 31, 2009
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Connect pc to tv
You will need a cable that connects the tv to the pc. If you pc has a vga connection and your tv has a vga connection, then you would purchase a vga cable and connect it. If the computer and the tv have 2 different types of connections you will need some type of adapter between the two of them.
Once you get them connected with a cable you just turn the tv on and Select Input (Select either PC, Computer, HDMI) of where the tv should receive the signal.
On the pc if you just reboot it most times the image will appear on the tv. if not you can Press and Hold your FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display.
Apr 28, 2012 | Computers & Internet
Connect pc to tv.
Your TV will need an HDMI or VGA (15 pin) connector on the back, plus you'll need a matching connector on your PC. Get the right cable (eg VGA Male:Male) and connect them up. Then just set you TV input to PC.
Mar 06, 2012 | Gateway GM5472 PC Desktop
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
Jun 07, 2011 | Televison & Video
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Cannot get sound from desktop to flatscreen.
You have problem with wiring. You need two separate wires, 1 - pc-> TV (video), other pc->TV (audio). Audio cable - minijack to rc
Apr 14, 2009 | Computers & Internet
Flat screen zenith Z20LCD1 use as a moniter HOW? Thanks
this is from the manual:
When the input source is PC (Only for Z15LCD1)...
PC S ettup ((Z151L5CLC1RD1
onlly))
Connections
1. Set the monitor output resolution on the PC before connecting to the TV.
2. Connect the TV to the PC with the PC cable.
3. Connect the PC audio output to the TV's PC S OUND input.
Viewing Setup
1. Turn on the PC.
2. Use the PC b utton on the remote control to select PC .
it appears only the 15" model may be used as pc monitor
Dec 06, 2008 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Electro Med Services...
