I didn't see a manual online in searches.
It might be able to discover something from questions on the web sites sellling it, or ask your specific question and see if it is answered.
Example:
https://www.homedepot.com/p/SoundLogic-Bluetooth-Shower-Speaker-with-FM-Radio-and-Carabiner-in-Red-AWS-12-2970R/206079715
Quoted from llink above:
How to use FM Radio in this device
This question is from Bluetooth Shower Speaker with FM Radio and Carabiner in Black
November 28, 2015
How do I use the FM Radio in this device. The device description says FM Radio but there is no mention of how to use it.
Answer this Question
Answers (5)
December 29, 2015
If you push the middle button it will switch from Bluetooth mode to radio. The first time I used mine it immediately searched through all the radio stations it could detect and store that information. Kind of like when you plug in a new TV. Once that scan is done it will play the lowest numbered station, you then use the buttons on the left or right to advance to the station you want. Don't press middle button again or it will go to Bluetooth. Good Luck
December 5, 2015
Turn on the device with the power button and then press and hold the "play/pause" button down until you hear the radio. Press and hold the back and forward button to control the volume and press the back and forward button with a quick release to switch the radio channels.
December 28, 2016
Hold down the play/pause button until the radio turns on. First time you use it, it takes a couple of minutes to program the channels then use arrows keys to go through the programmed channels.
Testimonial: "Thanks. I went to the Home Depot site but couldn't find the questions and answers. With your help I was able to go back and find the specific answer I needed."
SOURCE: Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
SOURCE: Can't tune to any radio station
HI,
I'll let you know if there is a factory reset button button for this model.
SOURCE: manual for KLH R7000 receiver
i searhced for a manual but i couldnt. i havve link maybe it works for you
check it
http://www.receivertech.com/klh-r7000-61-channels-receiver.html
SOURCE: instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
SOURCE: I have a Living Solutions
I purchased a used living solution iPod statio which works with iPhone however I am usable to set clock as I do not have owners manual model ATC 0899
