Https://www.bulova.com/pages/manuals-parts
User Manuals
Please consult the user manual that was packaged with your Bulova watch. If you don't have your Bulova user manual, please view our STANDARD MANUAL to read general information about how to set and maintain your watch.
You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, and we'll find it immediately.
For all other inquiries or assistance, please contact [email protected] or call 800-233-3350.
Parts Manuals
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second
hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown
all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands
will stop.
Step 2. Turn the crown to
move hands FORWARD (clockwise) until you see the date (for date only) or both
day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue
to move hands forward until the minute hand is approxim a t e ly 5 minutes
beyond the desired minute marker ;then ,gently turn b a ck to the same marke r.
For P. M .time , follow the same procedure ,but first a dvance the hands past 12 o’clock .
N O T E : The date will
advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been
established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The
refore ,on the fi rst day of any month
fo l l owing a month with fewer than 31 day s , the date must be advanced
manually (see Step 5).
Step 4. When the time
standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches
the 60th second, push the crown all the way to the “ I N ”position . All hands
will start instantly.
Step 5. Pull the crown to
the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will
continue to tell time. S l ow ly turn crown one way until the correct date a p
p e a rs .Then for day/date models, s l ow ly turn crown the other way until
the correct day appears .
N O T E : The day is printed
in two successive positions on the day indicator: i n English and in Spanish on
U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is
possible to make use of either position. The display will automatically re m a
i n in the language ch o s e n .
The
date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M
.a s this might affect the calendar mechanism and the accuracy of the date. (
Theme chanism will not be damaged if the crown is turned accidentally during
this
time
peri o d ,howeve r. )
Hope it helped U!
SOURCE: how to quick set date on n5 accuquarz bulova watch
Hi friend i am providing a link I hope this will help you out.
http://reviews.ebay.com/How-to-set-day-date-on-Bulova-Accutron-2182-movement_W0QQugidZ10000000006982861
Gud luck.
SOURCE: how to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right).
The "B" button is at the 10 o'clock position (upper left)
The "C" button is at the 8 o'clock position (lower left)
The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET
1. Pull the "M" button out to the setting position.
2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING
1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window.
2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise.
3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24".
4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons.
5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete.
6. Reset the time, calendar and other modes.
To set the time.
Note that changing the time in any of the cities will automatically update the time for all the cities.
1. Press the "M" button to move the mode hand to (TME)
2. Press either the "A" or "C" button to move to the desired city.
3. Pull the "M" button out to the setting position.
4. Press the "A" button. SECONDS will blink. Set them with "C".
5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button.
6. Press the "A" button again, and HOURS will blink. Set with the "C" button.
7. Press the "A" button again, and 12 or 24 hours tim format will appear.
8. Push in the "M" button to its normal position.
To set the calender
1. push the "M" button to move the mode hand to (CAL)
2. Set the city using the "A" or "C" buttons.
3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month.
4. Push the "A" button. The date (day) will flash. Adjust with the "C" button.
5. Push the "A" button. The YEAR flashes. Adjust with the "C" button.
6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands:
1. Press the "M" button until the mode hand is in (TME) or (CAL) mode.
2. Pressing the "A" and "C" button together.
The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction
Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
